Grand national lsx conversion?
Old 02-29-2012, 10:09 PM
6togo's Avatar
Default Grand national lsx conversion?
Hey all newbie to this site but was told come here for the best input on the lsx swaps!
I bought a GN last sping and doing a complete frame off restore into a pro touring car and had planned on doing a nice stage 2 v6 with a nice size turbo. The body is at local shop being painted and the guy there does allot of lsx swaps in older cars and said i should really go this route with a 80-90mm single turbo or get wild and do twins! He said parts are plentyful and way cheaper that the buick stuff plus the ls motors are very strong. So what i would like to do if i can is to swap the ls motor in and run a single now i would like to keep the a/c so is that possible?
Is there anyone that has fabbed a exhaust for a G-body with a single that fits without removing the wheel well or a/c box? Do most guys still run coolers on the ls's with single's?
Basically i need some input on doing this swap and what i might be in for!!
Thanks for any help!
Chris
Old 03-01-2012, 06:38 AM
6togo's Avatar
Anyone?
Old 03-01-2012, 06:55 AM
MNMCSS's Avatar
I to am also doing a swap, into a monte tho. I looked into the turbo stuff and decided to go N/A first then add a turbo in the future if i so desire. I am shooting for 400hp for this goal, which would be a jump over the turbo 6 even with a bunch of mods. Go over to the turbo mustang forum or to the forced induction section on here, there is a ton of info out there.
On a side note, The A/C with twins is going to get tricky! and the plastic inner fenders may pose a problem with exhaust routing. Not saying it cant be done but it will be a tight fit with ac
Old 03-01-2012, 07:26 AM
6togo's Avatar
My goal with the V6 was 750-850HP and it is very easy to see well over 400hp on a stock lower end v6. If i go the ls route i will be using a 6.0 with a stroker kit and run a single turbo that should get the numbers i want but i guess it will come down to cost,fabwork,and time! I know the A/C and fender wells might be a challenge but i would like to keep them and not cut them to hell!
Chris
Old 03-01-2012, 07:37 AM
MNMCSS's Avatar
Take a look at the truck manifold swap threat on the this site. That might give you some ideas. Not sure if you could fit something like a single 88 that way or not?
Old 03-01-2012, 07:39 AM
Old Geezer's Avatar
LOTS of info over on www.turbobuick.com
Old 03-01-2012, 07:40 AM
MNMCSS's Avatar
this is my setup, I pretty much just started and just fitting it first here. this is 1" setback
Old 03-01-2012, 10:31 AM
chuckd71's Avatar
Aren't real GNs pretty pricey and the regular Buicks hard to give away? Why not just sell the GN and throw an ls in a regular Buick. Personally I don't care but those Buick guy take that GN stuff pretty seriously. Turbo 4.8s and 5.3s seem to be popping up a lot, that might be a cheap approach as those things are everywhere.
Old 03-01-2012, 10:55 AM
Verz's Avatar
Here are a few I know of
https://ls1tech.com/forums/conversio...uild-swap.html
http://www.turbobuick.com/forums/thr...eed-gn.321944/
https://ls1tech.com/forums/conversio...l-turlibu.html
Now I know there are more, even posted on here, but since im on my phone too hard to look up. Keeping AC and plastic fenders shouldnt be a problem if youre creative. Welcome and goodluck
Old 03-01-2012, 07:46 PM
6togo's Avatar
thanks for the links i bought some GN doors from Stroker ace didn't know he had did the swap when i was at his house or i would have checked it out but i did contact him and he happens to be selling his setup so i may get lucky and skip some fab work! I live over the Turbobuick forum been reading all the builds there!
Chris
Old 03-01-2012, 10:10 PM
thenovaproject's Avatar
Nice g body
Old 03-02-2012, 07:04 AM
tta656's Avatar
Chris
been on tb.com for 16yrs or so....The serious buick guys are starting to learn not to be so uptight about the precious V6..
but there is more info to be learned here than at TB.com,read all builds,it may not be a g-body build that you learn from,,you can learn alot from all builds here..
Old 03-02-2012, 12:09 PM
BMF_Racing's Avatar
Question
Vertz mentioned my build in my Sig already. I really think you would be able to fab a 3 1/2" DP in the stock GN DP location, a 3" DP would be no problem at all. I know my air box is gon, but if you would like any certain pics just let me know, I can take some for you. What are your HP goals?
Either way good luck.
Old 04-04-2012, 10:13 PM
6togo's Avatar
Bumping this back up! Still trying to find someone that has done the swap and kept A/C/wheel wells anyone?
Chris
Old 04-05-2012, 02:00 PM
lamdenali's Avatar
Chris this is mine I bought it from a member here and on TB as well
Attached Thumbnails Grand national lsx conversion?-resampled_2012-03-11_18-45-36_78-1-.jpg   Grand national lsx conversion?-resampled_2012-03-13_18-54-16_80-1-.jpg   Grand national lsx conversion?-resampled_2012-03-13_18-52-54_836-1-.jpg
Old 04-05-2012, 02:08 PM
lamdenali's Avatar
All that equal to low 10 sec. car
Old 04-05-2012, 09:31 PM
6togo's Avatar
Looks good but i want to do a turbo setup with A/C any of your GN's sporting this?
Old 04-05-2012, 11:12 PM
lamdenali's Avatar
Nah, all mine either stage II with AC or heavy hitter 109 with AC, and a few LS without AC
Old 04-06-2012, 08:07 PM
gnx7's Avatar
Lamdenali- Love those gray colored TTypes. Had one myself.
I put a GN engine/trans into an '87 Mazda RX-7 and it weighed 2670lbs With a stock turbo and crappy launch (1.78 60') it ran mid 11's@114mph without locking up the stock D5 torque convertor.
Once I built a car with an LS motor.... there was no looking back.
Old 04-06-2012, 08:11 PM
chaman's Avatar
Good luck, but personally I would have left the V6 in it.
Quick Reply: Grand national lsx conversion?
