Thermastat not opening
Hello LS1 techies
I have a guy helping me finish up my Nova with an LQ9 in it. The thermastat is not opening. The car has been running enough for the gauge to read 210* 3-4 times. I have all truck accessories except the water pump wich is 98-02 Camaro WP. We have used 2 new thermastats.
1. Does the Camaro WP flow a different direction?
2. Just to make sure, does the water flow out the upper hose into the radiator & back in from the lower hose?
3. Any other possibilities?
Thanks
Thanks
Looks like everything is correct. Why do you believe it's not opening?
When you see the 210* temps is the top hose/top of the radiator hot?
Have you tried making sure the thermostats are good by boiling them in a pot an making sure they open?
Yes it will only flow one way for both car and truck setups. You seem to have the belts correct also.
Test the T-Stat/Housing.. pull it off and stick it in a pot of water, turn on the heat and watch it as the water starts to heat up. Use something to measure the temp of the water as tit starts to heat up or boil. If it doesn't open up around 195-210.. it is bad.
or just try another one.
BC
BC
As it appears you have the heater functional, try turning on your heater valve upon start up and see if your thermostat opens normally. If it does, then it's a simple flow issue where the hot water is not sufficiently circulating around your thermostat. In the Fbody, they incorporate a bypass heater valve that when closed (heater off), it circulates the water back to the cold side of the water pump. Though many argue it's not necessary, my wisdom is GM designed it that way.
Andy1
Andy1
There appears to be something wrong with the temp gauge. When the computer is reading 210* the gauge reads about 260* & if you rev the car the gauge bounces about 10*. The hotter the engine the more it is off. I am going to call the gauge company & see if they can help me trouble shoot.
Thanks for the responses, I can report back if anyone is interested.
The following users liked this post:
Turbojoe666 (11-06-2022)
This method worked for me also, I really don't understand it but it does work! You would think that hot water on the backside of the thermostat would be enough to open it, but whatever works!!!
For anyone that might be following along -- something I learned long ago is that it's pretty easy to actually test the t'stat out of the car to see what it's doing. T'stats get blamed for lots of stuff only to find out later that they weren't the culprit. If you ever suspect the t'stat isn't opening or is opening at a different temp than you expect - pull it out and test it. Put it in a pan of water on the stove with a thermometer in the pan. And actually see if/when it's opening. Removes a variable from the equation. FWIW....
To the OP - glad you figured out the issue.
finally pulled the top hose and did this and coolant is flowing. Looks like the top hose is above the radiator filler, and on the ls trucks, the expansion filler tank is higher than all of those. Always the simple things.
Even though this may be an old thread, after 30 or so ls swaps I have done I forget the small stuff. 5.3 into a short bed 94 c1500, really easy swap. Used the stock 5.7 radiator with stock 2003 radiator hoses. Filled it up and even used a vacuum assist filler (4 times) no coolant flow through the heater lines or through the radiator. The engine was seeing 210 through the gauge and non contact thermometer.
Andrew
