5.3 in 96 impala
Old 05-13-2012, 09:17 PM
Kerrick M's Avatar
Default 5.3 in 96 impala
need custom wiring harness or schematic for swapping 2006 5.3 and trans into 96 impala ss. i have both wiring harness, computers, engines, and transmission.
Old 05-14-2012, 06:43 AM
LS1Tech Sponsor
psiconversion's Avatar
We've done a few of them. Give us a call at 732-691-6531. Are you sticking with the DBW or going DBC?
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old 05-14-2012, 09:45 AM
bhop42's Avatar
Why are you using a fwd engine? Life would be a whole lot easier with a 5.3 from a rwd truck/suv.
Old 05-14-2012, 02:19 PM
the_merv's Avatar
You read it too fast..more then likely he has truck stuff..
Old 05-14-2012, 02:23 PM
bhop42's Avatar
I guess I did, my bad. Are you attempting to wire this yourself?
Old 05-15-2012, 10:51 PM
Scrap's Avatar
Good luck with your swap, post some pic's of the car....
-SS
Old 05-22-2012, 07:11 PM
Kerrick M's Avatar
changing my mind about doing the swap, i didnt know i had to change the oil pan, and accessories to one that comes off a car that comes with a 5.3
Old 05-23-2012, 08:43 AM
GA95DCMSS's Avatar
You don't have to change the accessories to one that comes from a CAR with a 5.3, as the only ones that did was the newer Impala SS and its counterparts. You can use the truck accessories, they just need to be modified a little bit. I ran them that way for almost 3 years like that with nary a hiccup.
Not knocking you at all, but if you have to ask for a schematic for combining both wiring harnesses together, then maybe you should stick to the LT1, or pay someone to do the combining of the harnesses for you.
*rant*I've done everything on my swap myself, besides rebuilding the trans. The rear gears/differential, initial install, wiring, TC install, Cam install, Tuning (with some help from Ed Hutchins)were all done by me. The reason for this is because I had my harness reworked by a vendor on this site, and on the initial startup, it would idle at oh say 2500-3000rpm. He blamed me, and said I installed it wrong, so I pulled the harness apart, and instead of REMOVING the unneeded wires, they were stagger-cut and tucked back in the harness, pretty half assed for the ~800.00 I paid for his services. He will remain nameless as I'm not gonna start bashing him, but I was beyond pissed at the his services rendered. *end rant*
Anyway, what was the question?
Old 05-23-2012, 07:02 PM
Kerrick M's Avatar
@GA95DCMSS i have no clue what exactly needs done!!! if i could get someone for example to say that i need such and such motor mounts, this oil pan, and what ac compressor bracket... then i would know if i was gone go through with it.
Old 05-26-2012, 04:10 PM
SStreet King's Avatar
http://www.impalassforum.com/vBullet...d.php?t=228454
Go here for all your Impala swap needs.
Quick Reply: 5.3 in 96 impala
