any other REAL Cadillacs out there with a ls swap?
Old 09-06-2012, 11:49 PM
Ls1.63cad's Avatar
Default any other REAL Cadillacs out there with a ls swap?
i got a 63 Cadillac coupe that im finishing a swap on and looking to find anyone with a 60-66 with a ls swap
Attached Thumbnails any other REAL Cadillacs out there with a ls swap?-043.jpg
The following users liked this post:
TOP CAT (09-21-2020)
Old 09-17-2012, 09:10 PM
alocker's Avatar
I'm considering this with a 66. Did you use a GTO pan to clear the steering? Looks good so far. Let's see more pics.
Old 09-17-2012, 10:34 PM
Ls1.63cad's Avatar
i used the GM muscle car swap pan its just a cast aluminum copy of a standard small block pan to make a ls fit in just about anything and the price was cheep for a GM part from the dealer like $160 for pan, pick up tube, dipstick, gasket, windage tray, and new hardware i plan to have it fired up befor the new year and will get some more pics up soon thanks
Old 09-17-2012, 10:52 PM
Ls1.63cad's Avatar
her are a few of the car and engine bay
Attached Thumbnails any other REAL Cadillacs out there with a ls swap?-021.jpeg   any other REAL Cadillacs out there with a ls swap?-021_1.jpeg   any other REAL Cadillacs out there with a ls swap?-025.jpeg   any other REAL Cadillacs out there with a ls swap?-045.jpeg
Old 09-17-2012, 10:58 PM
chuckd71's Avatar
How low does the muscle car pan hang in the caddy? Despite the name I can't recall seeing a car application in which it actually fit, it's just an H3 pan with a new name.
Swap looks good, plenty of room behind the grille for a turbo or two.
Old 09-18-2012, 06:09 AM
alocker's Avatar
Interesting. Does your Caddy have the centerlink behind the crossmember? The 65-66 uses a front sump style pan FYI. I'm curious if yours is the same.
Old 09-18-2012, 08:24 AM
cruisin'73's Avatar
Default Nice!
To true! You think GM would realize the huge market and mass produce a REAL muscle car pan for that $150. Bean counters rule the world...
Man there is enough room under that hood for ANOTHER LS! Its cavernous in there. Beautiful car man!
Old 09-18-2012, 03:54 PM
Ls1.63cad's Avatar
i would love to do a turbo or twins on it but not in the budget the pan sits about 3/4 in higher then the cross member. yes the steering is in the rear of the cross member like a 68-72 nova but this pan clears it by about an inch never seen the h3 pan but know this pans sump is 1.25 in shorter in height and 3/4 in shorter front to back and $300 cheaper then the Holley pan
Old 10-20-2012, 06:15 PM
Ls1.63cad's Avatar
bolted down for the last time engine radiator fans manifold intake and headers on for good now time to start laying out the fuel lines and harness also known as the not so fun stuff
Attached Thumbnails any other REAL Cadillacs out there with a ls swap?-012.jpeg   any other REAL Cadillacs out there with a ls swap?-011.jpeg   any other REAL Cadillacs out there with a ls swap?-013.jpeg   any other REAL Cadillacs out there with a ls swap?-014.jpeg   any other REAL Cadillacs out there with a ls swap?-015.jpeg
Old 10-20-2012, 09:53 PM
Jimbo1367's Avatar
Originally Posted by cruisin'73
Man there is enough room under that hood for ANOTHER LS! !
LOL. I knew someone would say it. I was thinking it as the thread was DL
Old 10-26-2012, 10:27 AM
cadivette's Avatar
I have a Cadillac (CTS-V) engine cover in great shape that would look nice on there.
Great swap, you don't see many of these now a days.
Old 10-26-2012, 01:47 PM
mjcotroneo's Avatar
got enough room for a nice giant pair of turbos lol
Old 10-27-2012, 10:17 AM
Ls1.63cad's Avatar
cadivette what you looking to get for that cover ?
Old 10-27-2012, 10:49 AM
bigblk74's Avatar
im in the process of of installing a lq9 in my 77" coupe deville... i'd call it a REAL cadillac...
Old 11-01-2012, 03:18 PM
sledcase's Avatar
Sweet.....Im firing up mine this weekend hehehehe 1966 devile 2002 ls1
Old 11-05-2012, 09:33 PM
Ls1.63cad's Avatar
sledcase do you have a build thread on the car would like to see how yours turnd out not alot of big old cadis with this swap. well my coil covers are allmost done just a lil airbrush and clear
Attached Thumbnails any other REAL Cadillacs out there with a ls swap?-004.jpeg
Old 11-23-2012, 08:37 PM
Ls1.63cad's Avatar
set the finished covers on for a photo and got some of the wiring laid out and the ecm and engine fuse relay box mounted still got a ton of wiring to lay out this car has power everything might take a brake from wiring and build the battery box
Attached Thumbnails any other REAL Cadillacs out there with a ls swap?-030.jpeg   any other REAL Cadillacs out there with a ls swap?-032.jpeg   any other REAL Cadillacs out there with a ls swap?-033.jpeg   any other REAL Cadillacs out there with a ls swap?-012.jpeg   any other REAL Cadillacs out there with a ls swap?-010.jpeg
Old 11-23-2012, 08:47 PM
Ls1.63cad's Avatar
i cut the power steering and alternator brackets apart cut the center part out then remounted the power steering then mounted the alternator to the lower of the two holes just have to clean up alil and weld the new sleeve for the second bolt on the alternator bracket and mount the idler pulley bracket sofar looks like it will work and gave me the room i needed for the hood
Attached Thumbnails any other REAL Cadillacs out there with a ls swap?-023.jpeg   any other REAL Cadillacs out there with a ls swap?-033.jpeg
Old 12-06-2012, 02:30 PM
Horace P's Avatar
Great project... what headers are those? and what trans did you use? if you don't mind (curious about how high i will need to raise the tunnel or if i will even need to)
I just started tear down of my '63 convert. Will be getting a 6.0/4l80 and a complete body off resto.
Old 12-06-2012, 06:41 PM
adanieljohnson1's Avatar
Very awesome swap!
Quick Reply: any other REAL Cadillacs out there with a ls swap?
