Fox body turbo set up. Ideas...
So I just got a 1990 fox body coupe with plans of doing a LSX T-56 swap. Pretty much what ever size engine (4.8-6.0) I find first for a good price I'm going to buy. Iron block for the 68-70mm single turbo, port and polished heads, LS9 head gaskets, stock exhaust manifolds, McLeod hydraulic clutch conversion, florida50 gauge cluster, Intercooled, LS2 timing chain, LS6 intake, cam and valve springs. Manual steering rack and no AC. Going to tear down to re gap the top rings. Go big or go home! Shooting for 500-600WHP.
I'm still trying to figure out what kind of K-member and standalone I'm going to go with though.
Looking at either racecraft or Afco K-member. Want to keep the MM springs that are already on the car. Heard alot about AJE and Team Z but I'm not looking for a straight drag car just maybe test and tune days for fun. Going to driving it alot around town shows etc.
For the standalone I was looking at Holley Dominator set-up or calling up PSI to see what they can do for me.
Should be a good project for me and my dad when I get home from overseas.
Any thoughts, comments, ideas would be greatly appreciated
I like Aje kmembers and my car is a street car. I would go with a psi harness I didn't and I regret it. I modified a on3 performance turbo kit to fit my 6.0. So far so good. Just minor fitment issues. Flipped truck manifolds are popular. I have a set with vbands welded on but went with the on3 kit since I didn't have to build a merger.
Thanks I went to the website and they had a kit for the fox LS. Is your last thread pictures of the kit? I was thinking about pony down turbo kits and modifying what needs to be OR CX Racing??? With the Aje did you go with their a-arms and coilover set up? what fuel pump/set up are you using? I'm just trying to get everything I need so the car isn't down for long. I haven't even seen the car besides pictures. Jan 18th can't come fast enough!
im running a UPR Chromoly Foxbody/4.6 K member with UPR LSX adapter plates and 4.6 motor mounts..UPR offers spring perches to run stock style springs or aftermarket coil overs
i would use a set of flipped truck manifolds and fab up your own hot side if you can weld..WAY cheaper..im tig welding my entire hot side myself
for pumps i am running a Walbro 255 in tank and another inline 255.
Thanks sleeper thats what I was going to do with the manifolds. I called racecraft and the only think i didn't like was the fact that you have to use their steering rack. But the pan, header clearance and you can adjustable by 1" might make up for it.
I think my vision is turning a bit. I might go with a Super Vic Jr manifold with a procharger. Been doing a lot of research and I found a lot of good stuff on that set up. Aeromotiveinc has a real nice fuel system for 700hp. This is getting to be alittle over my budget but hey I've been overseas for 3 years so what the heck right?
thats why i went with the UPR k member....the other swap k members always have a "catch"..... have a CTSV oil pan for my setup and i can verify that it clears even with power steering on the UPR k member...I myself will be running a manual rack though
I will have to take a look at the UPR stuff again. My car is going to be mostly a street car so I'm looking for a little more heavy duty member like the autocross member. I think I have decided on my standalone as well. Holley Dominator.
Got a complete motor for 400. Also scored a LS6 cam, pushrods, valve springs, locks, and brand new valve seals for 250.
Starting tear down this week
sounds good. You should look into Denmah's articles on standalone fuel management setups. Holley kit and conversion harnesses with pcm flashing and dyno time are fairly expensive.
He is very resourceful and helpful regarding any questions you may have..
The first setup he did was using megasquirt for fuel only and an MSD 6010 box to control ignition. He even has a few base tunes to get the car cranked easily and dialing in the tune wouldn't be hard at all.
https://ls1tech.com/forums/forced-in...d6010-lsx.html
Or another option (which is what i'm going with with) is Micro squirt.. with a few electrical mods it can handle a V8 and control ignition and fuel. Again, he has a few base map tunes to get you on the road.
Either option with a wideband will run you about 700-800$ but a far cry from what other alternatives are.
The Holley kit uses its own computer, so what PCM flashing are you referring to? Includes a start up tune as well as a self-learn feature. VERY nice system, that several guys on here are using with great results. VERY user friendly software as well. It seems a little pricey it first, but if you factor in PCM flashing and dyne time that other systems require, it really is pretty reasonable.
From my findings the holley also does well with forced induction. Going to the turbo shop today to see what they think.
Still trying to figure out what k member to get though.
Been on the phone getting quotes all morning
https://ls1tech.com/forums/small-blo...k-warning.html
I just got my Holley Dominator setup in.
If ur considering it U should down load the software off their web site and play with it.
REALLY easy to navigate and understand, I cant wait to get everything hooked up and start messing with it.
I've had a total of six mail order tunes done for my cars and friends cars. Every one of them ran fantastic and made within 10hp of the tuned cars did.
However, it is easy to alter some VE tables on a cam only car, but not so easy to do a mail tune with a turbo car with DIY pieces.
