1968 chevy pickup ls1 swap
Old 04-07-2013, 08:02 PM
jwardls1's Avatar
Default 1968 chevy pickup ls1 swap
We started a 1968 chevy pickup and decided to make it a fun truck we could drive anywhere. this is what we have so far. yes i know its not a short bed.
IMG_0055 | Flickr - Photo Sharing!@@AMEPARAM@@http://farm9.staticflickr.com/8401/8629429682_cdce0b750b_m.jpg@@AMEPARAM@@8629429682@@AMEPARAM@@cdce0b750bplans for the ls1 are just a mild cam and rebuild the transmission. As for the truck disc breaks on the front, 9 inch rear, lowered 3 inches, some custom interior pieces. color is to be decided the list will also get longer with the more research i do
Old 04-07-2013, 09:05 PM
ijimmy's Avatar
please keep this thread up to date as i have aquired a 68 c10 myself and am planing similar mods , but likely an ly6 or l99
will follow this one along
Old 04-14-2013, 08:22 PM
jwardls1's Avatar
i've been busy with work and have been waiting for motor mounts to come in so we freshened up the motor and trans. I hope the paint stays on...
[/IMG]
Attached Thumbnails 1968 chevy pickup ls1 swap-img_0260.jpg   1968 chevy pickup ls1 swap-img_0261.jpg   1968 chevy pickup ls1 swap-img_0262.jpg   1968 chevy pickup ls1 swap-img_0263.jpg   1968 chevy pickup ls1 swap-img_0264.jpg
Old 04-14-2013, 08:43 PM
jwardls1's Avatar
more pictures
Old 04-15-2013, 07:57 AM
Ian Johnston's Avatar
Looking good. Love these older trucks(67-87) I wish I had taken more pics when I had done my build, but not much of a photo taker until its too late into the project.
Keep up the good work.
Old 05-05-2013, 09:19 PM
jwardls1's Avatar
Ok so we got some key parts in and finally had some time to work on the project.
Parts list:
motor mounts
camaro oil pan
headers
radiator
radiator support
cross member
everything was going pretty smooth until we tried to mount the motor with the AC compressor on. There was just not enough room so we had to notch the frame a little. It fits barely...
progress is a little slow I know should be getting the cab back soon to start mocking up linkages and running wires.
Going to be using this for reference
Old 05-05-2013, 11:29 PM
How much room do you have with the sump to crossmember? My truck pan hangs down a bit, but plenty of room to Xmember. What engine mounts did you use? Those headers look the ducks guts. Wish we had that stuff out here.
Whats the radiator out of?, and how are you going to do the bottom hose? It looks the same as my radiator, and I ran the hoses over at chassis level to hook up. Thats how our cars were when LS engines 1st fitted.
Sorry about all the questions, just thinking of what I can change on mine later.
Old 05-08-2013, 08:15 PM
jwardls1's Avatar
As far as the cross member its a universal piece I can put it were ever I want so no clearance issues there. If your talking about the oil pan thats a different story this motor came out of a Gto so the pan would not fit in this case I had to order a camaro pan. Ill have to double check the name of the motor mounts and the radiator has penalty of room to play with to it is also from a camaro.
Quick Reply: 1968 chevy pickup ls1 swap
