64 Corvette LS Build W/ Art Morrison Chassis
Heres where it all started got the ca,r already had a LS1 in it but had a stock drivetrain, with 4 speed and stock chassis everything pretty original but not for long
Interior
LS1 only has 33000 miles on it
Tryin to figure out the stance for the new chassis these are the tire we will see if we can get them under the car and get the look we want
After all the math and backspacing and help from Scott at Art Morrison the Chassis has arrived
Stripped everything out
Out with the old
Had to cut the rear floor out in order to fit the new rear suspension an bigger tires with the narrower frame
Let the fitting and Fabbing begin
Interior
Out with the old
No not a drag car but 600 HP to the rear wheels. I have used some of the Art Morrison suspension before and had great luck with it. Should handle as good as the new ones we will find out
Fabbed up Body Mount
Here I used a replacement captured nut for the rear body mount on top of the mount I fabbed not pictured is the rear mount but i made it removable to make it easy to get the body on and off. Ifyou have ever taken one of these bodies off you know thw bottom of the rear quarter hangs up we fixed that LOL
If you look on this pis at the front of the frame rails are the front mounts had to do a little trimming for the big *** sway bar but its strong and works perfect
Should make the back out of lexan thats to pretty to cover up LOL
Shaved the door handles and took out the vent window and it aint goin back in One piece power window
No emblems gonna airbrush them on made new rocker skirt molds out of steel will soon be fiberglass
Seats getting bolted in
Cut the parking light turn signal housings off and glassed them up goin smooth
