thought I had a ls3 intake but my ls3 map sensor won't fit....help!
My intake is rectangle port and it has the map location behind the TB but for one thing the map sensor I got for a ls3 doesn't go into the hole at all. The part with the o ring that goes into the intake is too wide for the hole. And the intake has no other hole for the hold down screw.
Any thoughts?
Any thoughts?
I do not have any up close pictures of the map sensor location but it just has one hole for the o ring portion but not the secondary hole for the hold down screw. And the hole is way too small. Doesn't even get up to the o ring before its too the sensor is too big to fit. And it is a ls3/76 with rectangle ports....I'm stumped!
Yea I hear you. Of course out of the 150 pictures taken I have minimal intake pictures lol. But I will try and get one this week before Thursday if not Thursday I will post pictures.
Well did more research and looks like I have a l76 intake. L76 intake only has the hole for the map to seat into the intake. Now everywhere I look I cannot find a l76 map sensor. All searches come back with the gm number for the ls3 map. Which I already know doesn't fit.
Any one know of the l76 map part number? Auto zone and rock auto both show a ls3 map....
This is the one that is on my Ls3 manifold i got from GM Performance parts. My manifold came with intake, fuel rails, injectors, 90mm tbody, and this MAP...
http://shop.advanceautoparts.com/p/b...856/10016091-P
Does it look like this instead?
http://shop.advanceautoparts.com/p/b...686/18480872-P
I'd assume the one pictured above is what I need. I just hope I don't have to modify my harness more....Since I planned to run the lingenfelter map sensor adapter because my wiring harness was not modded for it when I got it done. Told them ls3 intake and they left map sensor on the back of intake.....
check out speartech fuel injection systems
they have some pictures of map sensors
you nshould be able to find out
what kind you need
what kind you need
