Adding a check engine light
Check these out:
http://www.snakebite.com.au/logodash...ach-p-494.html
Received this back from snakebite in Australia...I'll be ordering 4 lights over the winter...left, right signal, highbeam and check engine.
Here is the response...
Hi Leon, Thanks for your enquiry.
Postage/handling options to USA are:
Standard post $17
Pack & Track $23
Registered $23
I don't know of anyone stocking the logo lights in the
USA. Ours are engraved and we organise that here. There is
a stencil type around but I have heard it can wear off over time.
There is a dimension diagram of the lights on the website.
Go to logo lights, click on product, then click on tab marked
"extra images" and you will find the diagram down toward the
bottom of the page.
Kind regards
Vicki
Standard post $17
Pack & Track $23
Registered $23
bottom of the page.
Kind regards
Vicki
I used these for my cutlass dash for check engine, brake, turn signals, & high beams. There small and easy to mount. They come in many colors bright or defused. I used defused but honestly the blue is to bright for highbeam it shines right in your eye in my case. If you look close in pic I corrected the problem by covering it with blue masking tape.
http://www.ebay.com/itm/Flush-LED-Li...#ht_3697wt_943
or try these if you really want to be discrete...
http://www.designengineering.com/cat...ed-liten-boltz
Thanks to all who have added their input. Rocky topper...nice freakin dash man!
You could add a resistor in line to the blue LED...it'd dim it some. I had a similar issue with my cobalt blue autometer gauges...until I installed their dimmer.
