How do I ID a 5.3 vs 4.8 in a truck.
8th digit of the VIN:
4.3: W
4.8: V
5.3: T
6.0: U
8.1: G
This is out of my 2003 Silverado owners manual. Apparently, the 5.3T was
the GenIII LM7, and the 5.3M was a GenIV with AFM.
4.3: W
4.8: V
5.3: T
6.0: U
8.1: G
I seemed to have left out a crucial part. Sorry here's the correct information.
http://www.hotrod.com/articles/48l-or-53l-engine-guide/
Use bore scope & check crankshaft part #. For 100% accuracy .
I was looking for an 01-04 5.3 with a 4l60e. A 4.8 wouldn't be the end of the world but honestly why bother.
I honestly don't know exactly what I want. I know that I ultimately don't want to run cyl deactivation. I'm assuming a flex fuel would allow for some hot e85 tunes but e85 isn't as common here (Central Canada) as in the US so really a flex fuel isn't a deal breaker either way. Variable vlave timing would be cool but again not completely necessary. I'm assuming that I can modify a lot of those parameters with a tune or aftermarket ECU?
The wrecker has a 6.0 available but I'm starting to shy away from it only because of the cost and I'm leaning towards a lighter car so huge power isn't the end of the world.
It is ultimately going to go into a rat/hot rod of some sort.
