98 Temp sensor pin out?
Old 06-22-2007, 09:16 AM
RE AND CHERYL's Avatar
Default 98 Temp sensor pin out?
Any one know what the correct pinout for the 98 Temp sensor is? Tried search but came up with nothing.
Re'
Old 06-22-2007, 02:25 PM
LS1-450's Avatar
On the blue pin connector,
49 yellow wire ECT signal
25 brown wire ECT ground
Third wire goes to gauge
Old 06-23-2007, 09:25 AM
Any chance you can tell me the position of these wires. I'm using a GM TPS sensor plug I stole off a salvage yard car and the wires colors are different obviously.
Thanx
Re'
Old 06-23-2007, 09:58 AM
LS1-450's Avatar
brown top left (ECT ground), yellow top right (ECT signal), gauge wire is bottom center if you decide to use it.
Old 06-23-2007, 04:33 PM
Thanks.... I assume that's looking at the sensor side of the plug.
Re'
Old 06-23-2007, 05:05 PM
dsrour's Avatar
, The third pinout is a thermistor right. If so, anyone know what the resistance is at ambient temp?
Old 06-24-2007, 12:06 PM
LS1-450's Avatar
Re'
yes..
Old 06-24-2007, 01:23 PM
dsrour's Avatar
Thanks!
Quick Reply: 98 Temp sensor pin out?
