5.3 lsx pan on G-body????
Does anybody know if it will be able to fit without modding the pan. I ask this because the sump appears to not be as wide or as long as the f-body oil pan. Looking into buying one...what do you guys think?
I put one in my G body front clip that is now under my 51 GM pickup. Yes it is lower than the cross member, but still has plenty of room (just my opinion), but I don't plan on doing any 4 wheeling. by the way, my ride is on air & the front bumper will drop to 1.5" from the ground when deflated, & pan still don't touch the ground
Originally Posted by BLWN1
I have both if you need them... make offer, I say its too low, but it may work if you dont lower it
man i just sent these pics to somebody. Ill post em up tonight. Anyway, take your pan to a local welding shop an tell them to take 2" off the bottom and weld it back up. Its very easy to do, no pie cuts or anything are required. Any decent aluminum welder will be able to fill the gaps easily.
It will hang too low, mine was 3" below my crossmember. i Cut it, about 2", now its the same height as the standard pickup oil filter. Think i cut and welded it back up in like 25-30min if i recall, otherwise the fit is very nice.
Gary
Gary
my 5.3L unmodified truck pan is 2.5" below the "G" body cross member. The front end has stock height spindles with 235/45/18 tires. With the suspension fully colapsed on the factory bump stops, the pan is .75" off the ground.
(custom motor mounts sitting on factory isolators)
Larry
Larry
Gary
Gary
yeah i guess i didnt include the pickup. I shortened that as well.
