Where to connect coolant crossover line?
Where do I connect the coolant crossover line(under the intake/in front)? My radiator doesn't have any extra fittings to connect to and I don't think my water pump does either(truck pump). Do I run it to a catch can or block it off? I'm not sure where it's supposed to be going. Thanks.
Other options are:
Tee' into the upper Radiator hose
Tee' into the Heater hose
tap the flat spot on the water pump and connect there.
Add a fitting to the radiator neat the top of the tank (no you cannot (edit, sorry, typo) connect to the purge/overflow tank or the fitting on the Radiator cap)
