LS1 help and your opinion on wiring the harness
OK who do i go with on the wiring? i have the computer, harness ,engine and the 4L60. painless or spertech. i am going to leave the motor bone stock. this is out of a 2001 Z28. HEEEEEELLLLLLLLPPPPPPPPPPPP!!!!!!!!!
hear nothing but great stuff about SpearTech and Wait4me on here.
I hear lots of bad stuff about Painless' replacement wiring harnesses, but don't know anything about their LS1 conversion harnesses.
I chose to use Speartech. Buying a new harness gave the the option of having it longer than stock. The stock harness is a bit short and limits mounting locations. I'm planning on mouting mine behind the glove box in my '68 cutlass project.
I choose myself. The harness is very easy to work on and the main harness is very to depin at the ECU plugs. We pulled about 40 wires or more out of my harness and now its bare minimum other than my A/C stuff.
when you say you did it yourself what did you do about the vats ****. you just got rid of wires that you dont need. mine is going to be all stock and no a/c no p/s
sawzall wielding director
For the VATS you can either build a bypass box, or you can tune it out of the computer.
Even if the motor will be stock, there will still be some extra wires A/C, powersteering, emissions, etc. You can either leave those wires in the harness or eliminate them.
You dont need $350 to elimate the wires, cut the connectors off right at the harness and stick them inside the tubing then tape over it. Take your ecm connectors apart and remove the pins, cut the wires back at the wire junction, the wires will still be in the harness but will be hidden.
