Buying a Vowel - Truck Manifold Vacuum Port?
Old 03-03-2008, 09:32 AM
TomH's Avatar
Default Buying a Vowel - Truck Manifold Vacuum Port?
How are y'all getting vacuum from a Gen-III truck manifold? It's time for me to buy a vowel as GM used to have P/N 12559760, but it looks like it's obsolete and I cannot find a new P/N.
I could probably run a T-Connector off of the PCV line into the valve cover, but I'm guessing that there is a cleaner way that I'm missing.
Thanks in advance!
Old 03-03-2008, 09:39 AM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
I have that part number in stock
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 03-03-2008, 11:59 AM
TomH's Avatar
Jesse,
I sent a PM.
Thanks!
[Edit]
SDPC scores again!
Old 03-03-2008, 04:33 PM
pcmcobra's Avatar
can someone post a pic of the part and where it relates to on the manifold?
Old 03-03-2008, 04:56 PM
High on diesel fumes
thunder550's Avatar
I can't remember for sure, but aren't there a few nipples on the manifold that have little caps you can break off of them? You could also tap into the brake booster line, or PCV like you mentioned. There are several places...you should be able to find one easily.
Old 03-03-2008, 08:57 PM
TomH's Avatar
Here it is excerpted from a S&P tech article:
http://www.hotrodlane.cc/PDFFILES/Lisa%20Tahoe.pdf
Old 03-03-2008, 09:00 PM
TomH's Avatar
I can see the break-off ports, but also want to make sure that I'm not leaving a port open with the resulting vacuum leak. (I'd tap into the brake booster line, but that's the primary reason for this post, I cannot find it!
Old 03-03-2008, 10:03 PM
thunder550's Avatar
Ah ok I see what you're getting at. I didn't know what that part number was that you were asking about until you posted the picture. I got one of those from the dealer about a year ago....maybe they have gone obsolete since then? I dunno.
Old 03-04-2008, 09:19 AM
76LQ9TA's Avatar
I bought one of those about 1 month ago. It was about $4 from the dealer. It plugs into the rear of the manifold on the driver side. It was for vehicles without the power steering assisted brakes. If you engine had the power assist brakes, there is a solid plug on the manifold. It took them a while to find it. They seem to need a vin for every part lookup.
Old 03-05-2008, 12:35 PM
eagleuh1's Avatar
Dealer had one for me too. Mine came with the solid plug, ie hydraboosted breaks. I also broke one of the capped smaller lines off for the AC vacuum system.
Quick Reply: Buying a Vowel - Truck Manifold Vacuum Port?
