Drive by wire pedal travel distance
I've got an 02 LQ9 out of an Escalade with drive by wire. The drive by wire system works fine, but the pedal travel is very short. The throttle body is wide open at about 1/2 pedal depression. This could be a problem since I'm going to have to shorten the pedal lever to install in my vette.
I've tried 2 pedals with the same result.
Is there anyway to change this?
I'm using the 02 escalade TB, pedal, TPS, etc. But for some reason I was sent a non-compatible van TAC module from the salvage yard.
I saw the escalade TAC (12574221) cross referenced to some vans so I was hoping my TAC would work on the Escalade setup. Looks like I'm ordering a new one.
