5.3L truck motor bolt to T-56?
Will a 2000 to 2006 model 5.3L truck motor bolt up to a camaro T-56 transmission? Just making sure before I order a motor. Thanks
Also what is the RPO designator of the 5.3L?
Take your pick:
For 2008 Engine GEN4 models:
An iron-block non-flex fuel--------RPO LY5
An iron-block flex-fuel------------RPO LMG
An aluminum block non-flex fuel---RPO LH6
An aluminum block flex-fuel-------RPO LC9
GEN 3:
iron-block federal engine: LM7
Aluminum block/head : L33
2004 only aluminum block/head: LM4
Iron block flex-fuel: L59
GEN 3:
by the way, if you are going to get a 5.3, try to look for the L33 (aluminum block with 799 heads which are the same as LS6 heads)
