SN-95 LSX swap build thread
I decided to build an SN-95 after putting the 2013 Coyote Mustang on the scales. To my shock the race weight was almost 3900 lbs. Not wanting to ruin a brand new car with the weight reduction that would be required to run single digits I purchased a 1994 Mustang GTS V-6. The perfect blank canvas to build a single digit street/strip car. With the foundation of UPR suspension, Viking shocks, Racestar wheels, and a Moser 8.8 rear end. On the exterior I plan to update to a Cobra front bumper, Keanan 6″ pin on extended cowl hood, new head lights and taillights, and a fresh coat of white paint with blue pearl. Kirkey Seats, Coast Chassis roll cage, Heads Up fiberglass dash, and Racepak UDX dash will complete the interior. Fuel will be supplied by a Magnafuel pro-star 500 fed from a trunk mounted 10 gallon aluminum fuel cell. While the final engine details have not been decided.
Engine Out
Interior gutted
6" Keanan pin on cowl hood
Fuel door delete
Viking double adjustable rear shocks
UPR LS swap K-member
UPR anti roll bar and full length sub frame connectors
UPR Solid UCA's and LCA's
Strange single adjustable coil overs
Engine Out
Interior gutted
Fuel door delete
Test Fitting UPR K-member
Flaming River Manual Rack
Maximum Motor Sports Bump Steer Kit
Wanted to get more done today but I need a reamer for the bump steer kit.
Got a few things done today. Should have the rear end done this week so it can roll again.
UPR anti-roll bar
UPR anti-roll bar
Waiting on the rear brakes to show up and the rear end will be ready to go.
UPR anti-roll bar
UPR anti-roll bar
Got some work done on the rear end today hope to have it all together by tomorrow.
8.8 from 2000 Mustang GT
Housing ends cut for clip eliminators
New pinion bearing installed
35 spline Moser axles with c-clip eliminators and 5/8" studs
Solid bushings installed
Axle tubes welded and new bushings installed
Pinion installed
Moser spool
Strange chrome-moly 1350 pinion flange
Pinion installed
Moser spool
Cobra front end and Kennan Hood
Side view of hood and front end
Sound deadening removed
6" Cowl from inside car
Aerospace front drag brakes
17x3.5 Racestar 94 without cover
Nice. You could spend a day removing all the sound deadener with a heat gun and some scraping tools. I did the same, filled a 5 gal. bucket and was surprised how little it weighed compared to to older cars. The Cobra front bumper really changes the look, I'd like to do that too. Isn't the `99-04 axle housing wider than the `94-98? Are you looking at 6.5 offset rims?
Thanks, haven't made anymore progress, but had some parts come in today
Heads Up Composites fiberglass dash
Troy's Innovative Motorsports aluminum wing
Up and forward header
Scott Rod cowl and fire wall cover
Scott Rod firewall filler pieces
Strange manual brake conversion attached to pedal
Removing the glass and cutting the top off is the the preferred method for a lot of builders but, it seems like a lot of extra work when the main hoop can be dropped through the floor pan (through some 2" holes) before it's welded in to access welds on top. It looks like it's coming along well. Are you mixing 1.750" and 1.625" to build that cage?
