Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
HUD install
Old 09-04-2007, 10:01 PM
seabirdak's Avatar
Default HUD install
Is it possible to put a Heads up display in a Vette that didn't come with it?
Old 09-04-2007, 10:06 PM
~JOSHUA's Avatar
I searched under "heads up display" and I found your answer instantly.
https://ls1tech.com/forums/showthrea...=heads+display
Old 09-04-2007, 11:25 PM
seabirdak's Avatar
Old 09-06-2007, 07:06 PM
VortechC5's Avatar
Yes you can and it is easy to do. I have done a couple of them. If you have any questions about the installation post them here and I'll try to help out.
Old 09-08-2007, 09:00 PM
seabirdak's Avatar
Bump. What display's does the HUD have? Speed, etc?
Old 09-08-2007, 10:49 PM
LETHL_SS's Avatar
You can only add it if your cluster has the option to do it (depends on the year). Gene at GMPartsHouse.com can hook you up with the parts needed... should be around $350ish. Just be really carefull when you cut your dashpad. There is somewhat of an outline underneath but its not accurate as far as how deep towards the windshield to cut.
Yes HUD has speed, watertemp, oil temp, oil pressure, fuel level, ect... even has a shift light
Old 09-09-2007, 08:34 AM
LETHL_SS's Avatar
10279814 – HUD
12198648 – Switch
10425223 – Bezel
Heres the PN's needed as long as your cluster is compatable.
Old 04-29-2009, 06:22 AM
IntercooledC6's Avatar
I have one for sale for 05/08 C6 "non hud corvette's" HUD heads up display if any body is interested.. complete can install pics available.
Larry_cgr@yahoo.com
Larry
