No 12s for me this year.....
not bad for a relatively stock car... tell me, without cam or heads can you really tell me you expected 12s out of the car?
edit: looking at your 60, if you can cut it a little shorter you can probly grab a high 12
This is a very stupid comment. He was .03 from the 12s. This means in less time than it took you to type one letter of this post, he could have been in the 12s. A bit cooler, a bit less humidity. A bit faster 60ft. like you said and he was there. So why would you make the comment you did? Just looks like time to insert foot in mouth.
Wow seems like a fairly high pressure. I don't know what the setup was with the 8 psi, but 25 seems high event for a stock stall? You guys know these cars in and out so I gotta assume you know what you are talking about.
To the op do you run a norwalk? Stinks they close so early! Don't know where you live but if you want to give it one more shot look at Milan, MI they have two more weds they run! i am going the 21st.
To the OP, damn shame your local track closed for the year. I would ditch the front sway bar and make another run at it.
