New best time of 7.7 1/8th
Old 02-17-2013, 08:31 PM
bigantws6's Avatar
Default New best time of 7.7 1/8th
I did my best time today I was stuck in the 8.2 for a good min found out it was the fuel pump had low pressure then time drop after pump to a 8.6 had a wire short fixed the problem and did my best time still having a short somewhere hope to see what it does with a clean run
Old 02-19-2013, 05:04 PM
1Bad97WS-6's Avatar
congrats on the PB.
Old 02-19-2013, 09:24 PM
bigantws6's Avatar
Thanks bro still had a little short with the wiring but I pulled the cable that went to the starter and it was melted and arking with ground so I pulled the whole wire and fixed it and wrap heat wrap around it it cut off little pass the half track mark
Old 02-20-2013, 06:29 PM
bigantws6's Avatar
Old 02-24-2013, 08:18 PM
Blackpanther99's Avatar
Nice pass!
Old 02-27-2013, 01:58 PM
s346k's Avatar
nice pass. just curious, what stall is that?
my bolt on car went the exact same time - 7.71 @ 88.xx on a 60' that was a tenth slower. but i had 373 gears, maybe that's the dif. i never got a 1.5x 60' out of it, i bent the stock tq arm and i think that had a negative affect on the car's ability to get below 1.65.
s346k's Avatar
wtf double post
Old 02-27-2013, 09:14 PM
bigantws6's Avatar
I have a 4000 stall and 3.23 stock gears
Old 02-28-2013, 08:49 PM
rhodes37's Avatar
Where was that wire cut at. I just found a spot like that not too far from the battery on my car. Just curious what kind of problems that was causing.
Old 03-02-2013, 10:16 AM
bigantws6's Avatar
The way I ran the wire is buy the header after a yr of sitting I didn't remember how it ran so where I ran it buy the header .the header melted the lining of the wife and was contacting with the header causing a short my gauges would go crazy and then the car would cut out and blew a few fuses were the main power hooks up to the fuse box gona take it again in a few weeks see if I can get it to a 7.6 with out it cuttting off after little half track
Old 03-03-2013, 10:13 AM
Doug G's Avatar
Great looking 60' and congrats on the PB
7.7 = about a 12.0 1/4
Old 03-06-2013, 09:31 PM
bigantws6's Avatar
Thanks I hope it runs flat 12
Old 03-18-2013, 07:42 PM
I8UR4RD's Avatar
7's is fun territory. I remember being stuck in the 8.2 range, there is always that one thing your missing to get to 7's. For me it was tire pressure, and flashing the converter instead of stalling it up.
I had a PTC 3200
A TSP 228R 114lsa
Nitto NT05R
and 3:73's
It ran 7.30-7.40's on the limiter.
Old 08-04-2013, 10:04 PM
bigantws6's Avatar
Went for a dyno tune today and my base was 281 HP lol I been doing 7.7 on 281 HP my tuner was able to get me 350 HP my number seem very low for my times I'm on a 232/234 598/598 112 lsa 241 heads stock bottom end 346 a4 with a 4000 stall
Quick Reply: New best time of 7.7 1/8th
