first time at track
first time at track
Went to the track first time ever last night. mods are moser 12 bolt 3.73 gears, kooks 1 3/4 Long tubes, and magnaflow catback. made 2 passes first was a R/T .524 60ft 2.148 1/8 8.678 83.31mph 1/4 13.364 @ 105.26 mph.. second run was R/T .253 60ft 2.093 1/8 8.641 83.54 mph 1/4 13.329 @ 105.50. Car is a a4 35 anv edition vert with street tires. im kinda dissapointed with the time could i have done better say a high 12s. ???
Yes last night grand Bend that was my car. First time ever on a track.
Your first run definitely looked better then the second even though you had the little bit of a lower time the second time around. Drag radials will get you into the upper 12s for sure.
Yeah, the first run felt stronger I had it in D on the first run. Second run we brought the tire pressure down to 27.5 and dialed the shocks to full firm and heated the tires better and had the tranny in over drive.
Well I'll share my experience, which isn't much. I knew quite a bit about these cars before I even had one. I knew that stock they cud do 13s no problem. I put a lid and cat back and drag radials on mine i thought Here I come 12.9, well in reality 13.6 Here i was. Ive since learned that what the car is 'capable' of, and what it will do in the real world are not guaranteed to be the same. I've never swapped gears, but I've heard they don't always deliver that much et. Took a shot of n2o for me to hit lower 12s. I say ur times are good so far.
^^^ Yeah this for sure!! But remember this is a viscious circle, more traction means you'll need more susp. to handle it! Then you'll want more power because it's hooking and on and on!! But Good Luck this is the insanity that we thrive on!! Larry
