6.0 HCI results
Old 05-08-2016, 12:08 PM
"MAC"'s Avatar
Default 6.0 HCI results
First off, Thank you intune motors sports for all your hard work they are an amazing shop for sure.
Car: 2001 ws6
Mods: in sig
Race weight: 3620lbs
Whorepowerz: 395rwhp and 365rwtrq
Couldn't get my 60' below a 2.0 possibly because of my hoosiers were sitting in the sun for awhile. Idk got a drag pack just need to order tires and work some other kinks out.
All my runs are the right lane and yes the track finally had the right date on the slip Dennis!!!!
Old 05-08-2016, 07:18 PM
346only's Avatar
Horsepower and trap speed seem low for the mods. Is the cam almost stock? I'm sure the car is heavy too, but I figured it would dynk 420+.
Old 05-09-2016, 07:07 AM
"MAC"'s Avatar
Cam is bigger than my old 231/235 cam. Problem is the power dies off after 6200rpms. Something is choking it so once said those issues are resolved and it can rev better then it should move out a lot better and make more power
Old 05-09-2016, 07:14 AM
346only's Avatar
Hope you get it straightened out. I look forward to some gains out of it.
Old 05-09-2016, 04:32 PM
"MAC"'s Avatar
Thanks you, I got the idle all straighten out so that's one step closer to getting all the bugs worked out.
Old 05-14-2016, 01:38 PM
"MAC"'s Avatar
Slips from friday the 13th drag strip
Right lane
Left lane
Old 05-14-2016, 09:52 PM
TravisMcGill2000's Avatar
Right lane was slick last Friday night. I spun bad myself. Ever figure out what causing it to drop off at 6200 rpms. That think should trap mid to high 90s
Old 05-21-2016, 05:25 PM
s346k's Avatar
something is bad wrong. those are bolt on car time slips. I'd look into the tune again and possibly the trans and or converter. do you have a dyno sheet?
edit: are you using stock ls1 injectors? what's the duty cycle look like on those...?
Old 05-21-2016, 06:30 PM
HCI2000SS's Avatar
What are the specs on the cam? Have you seen a profile of your tune?
Old 01-02-2017, 12:17 AM
"MAC"'s Avatar
Sorry been awhile since I've been on lol. Turns out my car was leaving in second gear. Trans is messed up. I got a th400 to replace it and then this happened. I was driving home from work and then the car said I had 0 oil pressure and it was over heating. Idk the cam specs and I haven't looked at the tune profile.
Old 01-02-2017, 07:28 AM
SCott5's Avatar
No offense but everything seems off about those times compared to the mods. You need to find out your cam specs, need to check your duty cycle, and look at your tune. Have you found out why your power is falling off so early? Could be from injectors, tune or cam. Who ported the 241s? Going to a 6.0 was a good idea but it seems with your combo you just added unnecessary weight.
Old 01-02-2017, 09:48 AM
"MAC"'s Avatar
My duty cycle for the injectors are 99%, my cam is bigger than my old cam which my old cam was a 231/235 cam, iirc the new one is something along the lines of 235/240 cam. Once i get it back I'll take another video of it and post it.
Old 01-02-2017, 10:03 AM
SCott5's Avatar
Injectors need to be changed first and foremost
Old 01-02-2017, 10:14 AM
SoFla01SSLookinstok's Avatar
The slp lid & stock MAF is very small. Your motor wants more air. I'd think a new induction would help nice.
Old 01-02-2017, 12:32 PM
"MAC"'s Avatar
For sure going to get 42lbs when funds are available
I agree, the build was with stuff I already had.
Old 01-03-2017, 11:54 AM
85Iroc's Avatar
Who did the port work on the heads?
Old 01-04-2017, 05:59 PM
"MAC"'s Avatar
Idk, my dad bought the car back in 2008 in Kentucky I took over payments and bought it from him. When I started moving the car that's when I found out the heads were ported. So flow numbers on heads I couldn't even tell you that either.
Quick Reply: 6.0 HCI results
