All Time Fastest N/A Stock CI, H/C
Old 02-05-2008, 12:42 PM
  #81
James Montigny's Avatar
James Montigny 11.892@113.00; 93 Firehawk (LT1 350); 4L60; 4000 stall; LE2 H/LE1HL C; full weight; 11/3/2007
11.89 @ 113mph timeslip at the Midwest shootout @ KCIR. (November 3rd)
Backed it up with 9 11.9x slips.
Full-weight street car + 275lbs driver. DA was barely above 100
LE2 heads, LE1HL cam, SS4000 stall, QA1 shocks, MT ET Radials, skinnies.
Hot lapping after a pair of 11.90 runs.
(full mods list, pics, timeslips, dyno runs and history of the project available at http://www.cardomain.com/id/JamesMontigny)
Video: http://s38.photobucket.com/albums/e1...t=JamesM-1.flv
Slip: http://i38.photobucket.com/albums/e1...ps/118slip.jpg
Pics: (wheels up) http://i38.photobucket.com/albums/e1...MG_6440v4f.jpg
(My Fav Burnout Pic) http://i38.photobucket.com/albums/e1...hootout-05.jpg
Old 02-09-2008, 01:46 PM
  #82
holley505's Avatar
Originally Posted by Demonicbird00
Demonicbird0010.998@126.93; 00 Trans Am(346); M6;Lingenfelter;stock heads;KOD Cam; 3260lbs; 04/07
http://content.godragracing.com/vids...emonicBird.wmv
-brandon
that is a fast cam only car. No porting at all on the stock heads?
What are the cam spec and drivability?
Old 02-09-2008, 01:54 PM
  #83
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Jugger and Magnus went like mid 10's cam only a while ago.
Old 02-10-2008, 09:06 AM
  #84
Navy David SS's Avatar
James has been added.
David
Old 02-12-2008, 09:40 AM
  #85
KsMySS's Avatar
I was reading this the other day and noticed that most of the people on this list have stock bottom ends. But what if someone did a rebuild with after market rods & pistons and bored it over the .005? I think that would probably make it a 347 but does that 1 c.i. throw them out of this class. Does that 1 c.i. really make that much of a difference? What if they just did a hone and threw some pistons in it? I'm guessing this would be ok otherwise the qualifiers would have said stock bottom end instead of Stock C.I. Just thinking out loud.
Old 02-12-2008, 09:47 AM
  #86
Demonicbird00's Avatar
nope stock heads....loook at the sticky below this thread for the Cam ONly list... i was bumped from #15 spot back in Dec.
driveabilty is good for me... others may think its a lil too radical.i still get 21+mph on th highway
cam is a 245/250 .611/.615 110+1
-brandon
Old 02-12-2008, 10:51 AM
  #87
KCFormula's Avatar
Didn't Futral go 9.97 w/ a 6spd NA stock ci?
Old 02-12-2008, 07:22 PM
  #88
Hasn't posted so I guess not
David
Old 03-08-2008, 02:31 PM
  #89
Gary Z's Avatar
New PB ET and Speed on same run - 11.760 @ 117.62 mph. The second timeslip is to confirm my Car # 27. Please properly respect my awesome reaction times - the result of consciously avoiding redlighting.
Attached Thumbnails All Time Fastest N/A Stock CI, H/C-timeslips3.jpg
Old 03-09-2008, 09:37 AM
  #90
Nice job Gary Z. You've been added to the list
Pretty slow race season so far.
David
Old 03-09-2008, 12:29 PM
  #91
10 Second Moderator
Torkman15's Avatar
David
I think the weather has alot to do with the slow season, I'm ready to roll but my yard has huge piles of snow everywhere.
Old 03-09-2008, 12:37 PM
  #92
Evilways's Avatar
You can change my posting to 11.37 @124+MPH (it's in the sig), I can post a slip if you need me to later. Still same set up, hope to lower those ETs next time at the track into the 10's.
Old 03-13-2008, 01:20 PM
  #93
RUQWIKR's Avatar
Are the head/cam cars stock crank, rods, & pistons, too? I think so, but just wondering. I'm comptemplating my next step as I decide on what big motor to build later this spring / summer to replace my extinct 427. Thanks. Dave
Old 03-13-2008, 01:44 PM
  #94
Displacement is calculated as bore x stroke, thus H/C installs do not alter CID.
Using larger diameter pistons (and thus a larger bore) or a different crank (altering stroke) would change CID.
The actual volume of the piston (negative or positive) or combustion chamber is not relevant to "displaced" volume.
Old 03-13-2008, 01:52 PM
  #95
camscam02's Avatar
Camscam02 10.970@123.20; 02 Camaro(346); A4;4400 stall;stock heads;MS3 Cam; 3370lbs; 11/07
Old 03-13-2008, 02:09 PM
  #96
RUQWIKR's Avatar
I understand the physics. You can get the same CID with a different bore / stroke combo.
However, can you be "legal" if you change pistons, rods, and crank (if needed or desired) as long as you leave the bore / stroke the same? I would think no, but I am not sure what the "official" party line is and what all the cars have in their shortblocks. Not pointing figures, just asking.
Old 03-13-2008, 06:38 PM
  #97
camscam02 - you've been added.
Not sure on you question about the changing out piston, etc. This particular "list" is for stock ci - period. Anything else goes. Aftermarket anything - just no power adders - BUT must be stock ci... stock LS1, stock LS2 - haven't seen, but ya stock LS7's... This isn't a purest list.
David
Old 03-13-2008, 08:25 PM
  #98
RUQWIKR's Avatar
David
Thanks...take care. Dave
Old 03-19-2008, 10:11 AM
  #99
chrs1313's Avatar
Chrs1313 11.11@123.2; 02 Z28 (346); A4;SS4000;stock heads;230/230; 3300lbs; 03/08
Old 03-20-2008, 07:49 PM
  #100
Nice job - updated.. David
Quick Reply: All Time Fastest N/A Stock CI, H/C
