will i need to trim the bumper to run 28" et drags?
like the title say will i have to trim the buper and the front of the wheel well to get the 28" etdrags to fit? they will be on 15x9 convo pros...i really do to want to cut on the body of my car. if i cant can i get away with a 27" tire?
thanks guys
joe
thanks guys
joe
Yeap, it's when the tire expands. With non-adj control arms there was about 1/4" clearance in the back and plenty on the front. Center the tire as mentioned by ndfrsd6 then trim or hammer the body for clearance. Both places that need to be clearanced are inside the wheel well and not visible from the outside of the car. It's not as bad as it sounds and pretty easy to do.
You may be able to get away without triming the bumper cover. It really depends on the wheel offset and how the tire sits in there. With adjustable LCA's you can move the rear forward or backward and may be able to find a spot that works. You won't need as much clearance on the front. Also, a trans am will be a little different than a camaro with fitting the tires.
If you run a stiff tire it will grow less so you can get away with less clearance.
thats interesting...i plan on running stiff wall slicks so maybe it will be ok
hey taws6m6 an i see a pic of what your setup looks like?
oh and i love the early avatar lol
I dont have any close up side pics where you can look at clearances. I have a few of me at the track with a late pic of the launch with the tire wrinkled, but thats about it. They definitely arent stiff though. Adj lca's where a must though, they would rub the rear without them for sure.
The 15x9 will have better clearance than the 15x8.5 that i have,but not much.With the ET drags you will need 1 inch clearance,minimum,for no tire rub.I had 3/4 of an inch and mine rubbed bad on the front.Your best bet is to move the rear back with the adj control arms,then clearance the rear bumper cover.But remember like others have said,there is a piece of metal inside the rear bumper cover that needs to be trimed back,or your gonna puncture a tire.
i would like to see them on the convo rims...if you got the new prototype wheels like i did around $275 with the correct backspacing to fit nicely, minor caliper grinding, they are actually 9.25"
yes i did get the new wheels...i got them directly from centerline. they had to make them for me when i ordered them. well they matched summits price for them they gave them to me for 194 each and gave me free lug nuts. yes these are the ones that you have to grind a little but i dont mind. if they are 9.25 then thats pretty cool i will have to check that out.
sounds good that is what i plan to run when i get the 12 bolt..do you think i will gain anymore clearance if i get the rear shortened any like 1" or 1.5" each side...thanks
