Drag Racing Tech
does nitrous effect gearing?
Old 07-10-2009, 01:17 PM
z28rob18's Avatar
Default does nitrous effect gearing?
i dont think i ever saw this posted but does nitrous effect the gearing of a car? i think it does but would like to see. i put 3.70s in my 9" and that should put me right at about 140mph at the top of forth. i have a set of 4.30s but from wat the calculator says id be at lik 123mph top of 4th. if thats correct then the 3.70s should be better for my set up right? 27" tire and a 6 speed goals in sig.
Old 07-10-2009, 03:29 PM
mike c.'s Avatar
What do you run now? What is your n/a 1/4mi mph? n.o.s usually adds 10-12mph more to the n/a times for the 125-150 shot. I do run 4.11's a 26'' tire and a 150 shot @ 134mph on my old set up. I have my rev set at 7,300rpm's so I can make it down the 1/4mi. My new set up is 130mph n/a and need to go more tire. But,MOST do go to the 3.73-3.90 gears for n.o.s. Then a 26'' or 27'' tire can be used easier.
Old 07-10-2009, 03:33 PM
z28rob18's Avatar
the car has no motor right now. but should be more then capable of reaching my goal. the motor going in is a 385 with a hefty HR 220cc heads and a 200 shot. i was just trying to see if 1. nitrous effects gearing in the rear and 2. if im using the right gears.
Old 07-13-2009, 04:46 AM
ineedamotor's Avatar
i could see how it could affect it, but nothing liek a turbo would.. well it could i suppose.. but well yeahhh....
Old 07-13-2009, 12:00 PM
robsquikz28's Avatar
Rob, i know someone running that exact same setup and it works awesome, its has a 250 shot with 4.11gear and 28" tire on stock rearend
Old 07-13-2009, 05:04 PM
Race your car!
JL ws-6's Avatar
I'm not sure how you're only going to be able to go 140 with a 3.70 and a 28 inch tire... you should be able to go alot faster then that unles you're shutting the motor down way too early (RPM wise)
4.30 and a 28 should be able to get you to 140+, which is plenty for the goal you have set.
Old 07-13-2009, 06:51 PM
SSPerformance's Avatar
how high are you going to turn the motor
Old 07-13-2009, 09:07 PM
Race your car!
JL ws-6's Avatar
Me, **** I'll spin it to whatever it takes
Anything less then 7200 and you're probably gearing the car too tall.
Old 07-14-2009, 06:18 AM
z28rob18's Avatar
27" tire. i did say it first post but idk. and it'll be spun to about 6800.
edit: seems like itll be good for 148. but im still wonderin if nitrous effects gearing
Old 07-14-2009, 08:42 AM
ATVracr's Avatar
As long as the clutch can hold the extra power it wont effect it.
Old 07-14-2009, 10:36 AM
7 Second Club
ty_ty13's Avatar
some nitrous motors prefer to be spun low and have tall gears... the slower the engine speed the more nitrous in each revolution thus more power per revolution.
Old 07-14-2009, 10:37 AM
7 Second Club
ty_ty13's Avatar
thats why nitrous motors make soo much torque early... more nitrous in each hole at slower speeds.
Old 07-14-2009, 05:57 PM
Firehawk441's Avatar
Exactly. It's not like blowing through to loose of a converter. Congrats by the way on your new 1/8 mile times. Awesome job.
