Drag Racing Tech
alternator mounting question
Old 07-23-2009, 08:26 PM
firefighting1101's Avatar
Default alternator mounting question
i have an iron 408 with all the accories gone except the alternator. im trying to figure out a way to mount it. i have the bmr mount, but it only works with the aluminum blocks. so how are you iron lock guys doing it?
Old 07-23-2009, 10:37 PM
SPEEDYws6's Avatar
Do a search... There is a hole you can drill and tap and use that same bracket.
Old 07-24-2009, 09:14 AM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
Some drilling and some tapping and you will be golden.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 07-24-2009, 09:32 AM
CanuckSS's Avatar
The Ohio boys had a neat alternator mount setup on their red turbo car. It was mounted to the frame rail instead of the engine block. I guess you would need to have the motor on solid mounts or a motorplate to utilize this setup.
Old 07-24-2009, 11:48 AM
tee-boy's Avatar
how about a custom bracket on the motor plate? just a thought.
Old 07-24-2009, 12:24 PM
pewter 01 SS's Avatar
this is what I'm trying to do. i'm in the same boat
Old 07-24-2009, 01:01 PM
Race your car!
JL ws-6's Avatar
Drill/tap. Not that hard to do, get the bmr bracket, and you can use it as a template to get a mark started on the block where to drill/tap.
Old 07-24-2009, 01:25 PM
i dont think people seen the block we have because there is no place to tap it on our block. i would have tapped it but like i said theres no place.
Old 07-24-2009, 01:53 PM
Race your car!
JL ws-6's Avatar
What block are you running?
Old 07-24-2009, 05:26 PM
thats the same with my block. there just doesnt seem to be a place to tap it. and i already have the block. its a 6.0 iron block. and i have the bmr bracket and tried to use it as a template, but it just doesnt seem to be enough room. ill try to take some pics tomorrow when im working on the car agin.
Old 07-24-2009, 08:03 PM
1CAMWNDR's Avatar
There is one spot on the far driver's side of the bracket that lines up with a spot that can be tapped. The center mount of the stock bracket does not have a mount on the iron block.
Old 07-24-2009, 08:59 PM
does anyone have any pics of this installed? it really bothers me to tap the block, and i dont want to screw it up lol
