Drag Racing Tech
Minimum pinion angle for the track
Old 08-30-2009, 03:45 PM
03 BUSA's Avatar
Default Minimum pinion angle for the track
I am currently running -1.3 and it will shake violently at 110+. Never noticed anything on the street as I do not drive that fast. I know I need to take some of that 1.3 out of the angle but at the same time I do not need the angle to go positive on launch. I have full rod end suspension. I thought I read somewhere that the rod end suspension cars did not need to run as much negative angle.
Old 08-30-2009, 05:01 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I've heard guys setting it at -4*
Old 08-30-2009, 05:51 PM
03 BUSA's Avatar
I think by the time it is all said and done I might be down there as well.
Old 08-30-2009, 07:35 PM
Randy WS6's Avatar
I have a full suspension , with drag bar and adjustable shocks and I run -3 pinion angle.
Old 08-30-2009, 07:56 PM
03 BUSA's Avatar
Is that 3 or .3?? Thanks for the help guys.
Old 08-30-2009, 08:04 PM
xpndbl3's Avatar
how do you even calculate such a precise pinion angle down to the tenth exactly? I'm at -2 with all rod end suspension in the rear, poly mounts or rubber mounts will want more pinion angle due to deflection typically. If you're not getting vibration until that high a speed I'd be looking at tires or driveshaft myself.
Old 08-30-2009, 08:27 PM
Race your car!
JL ws-6's Avatar
I run mine at about -1/2 degree. More pinion angle only does one thing: Add a bind to the drivetrain.
Old 08-30-2009, 08:57 PM
03 BUSA's Avatar
Thanks guys. I will reset it to around -.5 and see what it does.
Old 08-30-2009, 08:59 PM
03 BUSA's Avatar
Using a smart level. It is not tires or d shaft. Def it the driveline angle.
Old 08-30-2009, 09:11 PM
Randy WS6's Avatar
-3* total deg.
Old 08-31-2009, 10:04 AM
03 BUSA's Avatar
Why would you need that much angle in your drivetrain?? Just trying to figure out the differences between different setups. One has -.5 and the next has -3. Big split there. Althought the guy with -.5 does have a nice pic of a great wheelstand so I am sure it is not hurting his setup. LOL.
Old 08-31-2009, 10:48 AM
slow trap's Avatar
i think the more negative you have the more initial bite you will get. unfortunately it comes with down sides as well. i think mine is around -2* or so. with good suspension parts that won't distort you can get away with less angle and still hook great.
Old 08-31-2009, 11:10 AM
Race your car!
JL ws-6's Avatar
Kind of my point. If the car can do that with a couple adjustments of the shocks and the travel limiters... I'd say the pinion angle is o.k.
