Drag Racing Tech
deleting hvac. keeping heat.
Old 02-18-2010, 02:12 AM
Restricted User
kalebm22's Avatar
Default deleting hvac. keeping heat.
first off who all makes a delete plate?
what do i need to do to keep the heat?
ive read where i need to cut the front of the hvac off, this sounds hard?
Old 02-18-2010, 08:39 AM
thunderstruck's Avatar
burkhart chassis,bmr, pcmforless all make one
you can either keep the stock blower motor & modify the housing or get an aftermarket heater (i got a cheap summit one im installing)
search for hvac delete, there are some who did an excellent job of modifying the housing & have good pictures
Old 02-18-2010, 08:54 AM
BMR Tech's Avatar
One of the nicer installs I have seen MightyMouse did with one of our delete panels. I will see if I can find he thread.......
Old 02-18-2010, 09:00 AM
Internet Mechanic
BlackScreaminMachine's Avatar
I know of some who have done a Mohave Heater for guys like us in the North East. Having no heat and if there is alot of moisture and cold temps makes it very hazardous. I can deal with no A/C but no heat is a major PITA.
Old 02-18-2010, 10:20 AM
sweetbmxrider's Avatar
you cut what extends past the firewall since that is way the evap core is. the blower motor sits next to the heater core in the box but they are separated. you have to cut some of the box back so air can blow through. there are a few threads about it.
Old 02-18-2010, 12:04 PM
Restricted User
kalebm22's Avatar
ya ive read a couple of the threads but i havnt found anything that shows what i need to cut. i am just contemplating on whether i want to do it or not.
Old 02-18-2010, 02:17 PM
TS6
TS6's Avatar
Take it all out and get the Mojave heater.
Old 02-18-2010, 04:28 PM
Restricted User
kalebm22's Avatar
will i be able to keep defrost?
Old 02-18-2010, 05:14 PM
LadyDriven's Avatar
Hmmm... subscribing. I'm in the middle of this same issue! Cant decide to keep the heat or not
Old 02-18-2010, 06:14 PM
03 BUSA's Avatar
^^^and your in Canada??? Would like to find a good writeup on this as well. Right now I am up to around 200lbs off the car so far this winter with full factory interior would like t0 get closer to 250.
Old 02-18-2010, 06:39 PM
here ya go
https://ls1tech.com/forums/12181044-post7.html
detailed variation
https://ls1tech.com/forums/drag-raci...-c-delete.html
Old 02-19-2010, 10:46 AM
LadyDriven's Avatar
Yup! Not too far north though. I'm on Vancouver Island, just a few km from where the Olympics are being held. If you've been watching the Olympics at all, Im sure you've noticed how nice the weather is It doesnt get too frigid here, and anyways, my TA is mainly only a summer car. She goes on the road in early April, and off the road in late September. The only time I ever use the heat is to defog the windows early in the morning. I'm hoping some cheap aftermarket heater will work.
Old 02-19-2010, 01:00 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I took out the entire front half of the box on the firewall. I made a plate to cover the hole and cut a slot for the heater core lines and my heater still worked.
Old 02-19-2010, 01:16 PM
Race your car!
JL ws-6's Avatar
You can take the heat out completely, then mount the mojave heater so that it will blow thru the dash vent, and give you defrost. That's all you'll have, but if you think about it, that's the only heat that you really need, keeps the windshield clear, and I don't think you can ask for more then that.
The mojave is enough to heat the car too, it's not that big, but it will heat up the car enough so it's tolerable no problem. Just gonna have all the heat blowing at the windshield... but as long as you can deal with that, it's perfect.
Old 02-19-2010, 01:17 PM
LadyDriven's Avatar
How hard is it to install? Any idea on weight as well?
Old 02-19-2010, 01:27 PM
Race your car!
JL ws-6's Avatar
Not sure on the weight, but if you have access to any type of fab tools and can work with small round bar, you can easily get it in the car.
I've helped a couple people put them in other cars (not 4th gen f body's) and it's generally been a pretty easy go.
Old 02-19-2010, 01:34 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I had one that never used, it was about 8 lbs. You could easily mount it inside the dash.
Old 02-19-2010, 02:23 PM
LadyDriven's Avatar
Wanna sell it?
Old 02-19-2010, 04:37 PM
studderin's Avatar
check my build thread, I made a lightweight "heater box" with my stock blower motor housing pushing thu a light alum heater core. Plugs right in like stock uses the factory contorals.
I looked into the movac, what I did was cheaper but little more work to do. MM uses the granger blower box, I bought it. It was heavier and louder then the stock blower hosuing. So retruned the granger box, and used the stock blower setup.
https://ls1tech.com/forums/drag-raci...itch-diet.html
Old 02-19-2010, 04:38 PM
studderin's Avatar
Quick Reply: deleting hvac. keeping heat.
