Drag Racing Tech
10" rim & tire questions
Old 04-13-2010, 05:22 PM
Sofls1's Avatar
Default 10" rim & tire questions
After doing a search, I am a little confused as to what exactly needs to be done to fit a 10" wide rim and 26x10 slick on the rear. I am aware of the rear brake grinding and that's not a problem, but what about the bump stops and fender lip?
I also read that with an 8" rim there are no clearance issues other than the caliper with the same tire, is this true?
Old 04-13-2010, 06:17 PM
MikeG's Avatar
The fender lip isn't an issue with a 26" tire unless your car is very low. The bumpstop might be in the way with the 10" wheel. I just cut mine off. With the 8" wheel there are no clearance issues anywhere, other than the calipers.
Old 04-13-2010, 10:41 PM
Sofls1's Avatar
My car is pretty low, and the way the housing looks I'm on the bump stops all the time, so I kinda want to keep them. Is anyone running a 26X10 tire on a 10" rim that still has the bump stops?
Old 04-14-2010, 07:40 AM
monster81's Avatar
i've cut the bump stops cus im curently running 325s. but i do know that with 7.5 backspacing on 10" wheels bump stops wont be a problem. im not sure if the slicks will clear them but u have to put them on and check. keep in mind that slicks will grow as they get warmed up.
Old 04-14-2010, 03:04 PM
Sofls1's Avatar
Thanks for your reply, I couldn't understand why people were telling me that a 275 or 26X10 would clear with an 8" rim but not on a 10" rim.
Old 04-14-2010, 06:31 PM
Nabdrill's Avatar
With Draglites, 10" wide(7.5 BS), 275 MT, and 1" lowered in rear I had to remove my bumpstops and brackets
Old 04-14-2010, 11:34 PM
spoonraker's Avatar
I just mounted up my 10'' wheels today.
15x10 RaceStar Industries, 7.5'' BS. 275/60/15 drag radials.
The 28'' tire with stock shocks/springs had no issues fitting in the fenders/wheel wells, however one side did require the bump stop to be ground off. I'm not sure why only one side rubbed the bump stop, the rear end looked pretty centered, but when you're dealing with clearances of about a half inch who knows.
I think with a 26'' tire, unless you're more than 2'' lowered you shouldn't have any wheel well issues. There's really no way to tell if you'll need to grind the bump stops until you mount up the wheel and look.
Old 04-15-2010, 04:09 PM
Sofls1's Avatar
The Section width of the tire I'm using is 11.5 while the section width of the stock 275/40 17 is 11.0. So without having them here in my possession (yet) I'm guessing its going to only add 1/4" to each side (given the bs 7.5 is the same as a stock 10 spoke). However, if the 7.5 draglite moves the tire in toward the car, I may be in trouble.
Old 04-15-2010, 05:43 PM
sweetbmxrider's Avatar
sounds like you need an adjustable panhard bar
