changing converters
Restricted User
changing converters
i curently have a fuddel 3600 converter and am looking at going with and edge racing custom converter that is around 4000 rpms. what do you guys think? ik that yank, vig, and circle d make some awsome converters but they are out of my price range. with the mods in my sig how much do u guys think this swap will help out?
We need more info before trying to spec out a new converter, like if you were on the dyno, where did you make peak hp and tq and what do you rev to ? Or what does your car 60ft and what's the e.t. and trap speed in the 1/4 ?. If your serious about trying a higher stall, I would call the converter company up and ask them, their the pro's that do this for a living.
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
Everything stated above is good advice.
You get what you pay for. Make sure your combo is done (or as close as possible) before specifying one out. If you are planning to spray the car a bunch, the converter selection might change versus N/A.
Derek
Derek
do not try to cut corners when it comes to converters. you can do a search on tci for example and read thru all the horror stories. i'm running a Vig triple-disk and it's been working great. save up and buy a quality converter or you'll be paying A LOT more when replacing the trans.
Restricted User
i shift at 6600 rpms, i already have a 3600 converter but it is a fuddle and it has been a good converter but i feel like im leaving some on the table. i planned on haveing edge build me a custom converter. they charge 550 for a custom converter and i did some research and noone seemed to have any fail. i havnt got to run the car at the track cause it doesnt have a cage but i put an autozone starter on the car and it wrecked my flywheel so now i have to pull the trans and i am goin to go ahead an upgrade it while i am in there. i dont have alot of cash as i am trying to buy an 02 chevy truck at the moment.
"All Motor 9 Second club member"
I would keep the Fuddle until you can swing the coin for a Circle D 2E 4000 stall if you are staying NA or a Circle D 5C if you are going to spray. The Fuddle is comparable to the Edge IMO and not worth spending the money on unless you have a problem with the Fuddle. A 5C will be a HUGE improvement over your current converter and well worth the money and time spent. You could always sell the Fuddle to help cover the cost of a quality converter. G/L
