Drag Racing Tech
Couple of Specific Roll Bar/Cage Q's..
Old 01-28-2004, 03:16 PM
Motorboater
SilverGhost's Avatar
Default Couple of Specific Roll Bar/Cage Q's..
yeah, so I did a search on here and the web, found some info on my questions, but I must be some kinda f'n retard man because I still need some clarification
1) So what exactly IS the rule NHRA wise for T top cars next year? Specifically if my car runs in the 10's(10.00-10.99 e.t range) with Ttops, what will be required of me NHRA tech wise? Will a 6 point bar do the trick, or am I going to need a 10 point cage?
2) My second question is this, since I'm really hoping I can get away with a 6 point bar...I tried finding out what it takes to make the wolfe bolt in ones NHRA legal, but couldn't. What would need to be done to a bolt in to make it cool beans with the techs?
TIA, that's all I got
Old 01-28-2004, 03:41 PM
BIGBOS's Avatar
I'm curious about this as well, probably gonna have a cage done this fall.......
Old 01-28-2004, 03:54 PM
Formerly 4mulaJoe
LS1x2's Avatar
To tell you the truth, in my experience you are going to get conflicting answers online. You should buy the $10 rulebok and read it, or if you are going to have a chassis guy do all the work let him handle all of that for you. Just my $.02.
Old 01-28-2004, 04:08 PM
Motorboater
yeah i know, i just wanted to get an answer quick rather than wait for the book in the mail, but if i can't get a 100% answer here I'll order the thing up.
Old 01-28-2004, 04:16 PM
ONEBADWS6's Avatar
10.99 Holly Shi* I need spots!
Old 01-28-2004, 04:30 PM
Motorboater
whatever racecar driver
quit hijacking my thread, an answer is needed
Old 01-28-2004, 05:11 PM
SLowETz's Avatar
From the '04 rulebook:
Roll Bar
Roll bar mandatory in all cars (including T-tops) running 11.00 (*7.00) to 11.99 (*7.49), in convertibles running 11.00 (*7.00) to 13.99 (*8.59).
Roll Cage
Roll Cage mandatory in cars running 10.99 (*6.99) or quicker or any car exceeding 135 mph. In full bodied cars, with unaltered firewall, floor, and body (from firewall rearward, wheeltubs permitted), running between 10.00 (*6.40) and 10.99 (*6.99), roll bar permitted in place of cage. In convertibles running 10.99 or quicker, or exceeding 135 mph, roll cage mandatory. Cars running between 7.50 (*4.50) and 9.99 (*6.39) must have chassis inspected every three years by NHRA and have a serialized sticker affixed to cage before participation. Plating of chassis prohibited for all cars manufactured after 1/1/2003.
Pertinent General Regulations 4:10, 10:6
4:10 Roll Bars
Swing out sidebars permitted. Side bar must be included on the driver's side, and must pass the driver at a midway point between the shoulder and elbow.
Unibody cars with stock floor and firewall (wheeltubs permitted) may attach roll bar with 6-inch x 6-inch x .125-inch steel plates on top and bottom of floor bolted together with at least four 3/8-inch bolts and nuts, or weld main hoop to rocker sill area with .125-incc reinforcing plates welded completely.
10:6 Head Protector
In any car where a roll bar or roll cage is installed, a padded head protector must be provided at the back of the driver's head and constructed in an attempt to prevent whiplash upon impact. The roll bar or cage must be padded wherever it may come in contact with the driver's helmet.
Old 01-28-2004, 06:28 PM
Motorboater
Awesome info man
But it only raises a few questions still.
1) Is a t-top car considered full bodied or a convertible, because I've heard they were considering T tops same as convertible.
2)I keep seeing people say that a bolt in can be made legal just by welding the bars to the hoop, but it says that is for unibody cars, which an f body is not, correct?
Old 01-28-2004, 06:30 PM
NRC-Motorsports's Avatar
like low et posted ROLL BAR allowed this year , who knows for next year we wont know till closer to end of year, you know NHRA if the bolt in bar is bolted together [i think 2 back bars] they must be welded to main hoop
Old 01-28-2004, 06:36 PM
Awesome info man
a camaro is a unibody car ,only cars with full chassis are not considered unibody i.e. chevelles,corvettes,malibus for a few, car with front sub frames and k members are still concidered unibody
Old 01-28-2004, 06:52 PM
11 Bravo's Avatar
So what point roll cage is mandatory for 10.99 and quicker? 10 point?
Old 01-28-2004, 07:43 PM
SLowETz's Avatar
The way I'm reading it....6 points of attachment are good for 7.50 and slower, but tubing code specs, and diagonal bracing must be adhered to.
Old 01-28-2004, 08:14 PM
Motorboater
Well I think I'm going to consider doing a cromoly bolt in and weld the bars to the main hoop.
Wolfe has that kit that turns a 6 point into a 10 if that ever becomes necessary but I sure hope it doesn't, I like cruising the car with the tops off and don't want some ugly *** cage showing.
Thanks for the help all
Old 01-29-2004, 07:49 AM
you have to read the national dragster thru the year or check with NHRA ON UPDATES BECAUSE THE BREAKOFF AS OF JAN. IS 8.50 OR SLOWER ,BETWEEN 7.5 AND 8.40 YOU NOW NEED A 25.5 TYPE CAGE [SORRY ABOUT CAPS FORGOT TO TAKE OFF] you should always check with NHRA [ihra] on changes thru the year before a major undertaking, essp. if your doing it yourself ps ,anyone with a cert on thier car now will be granfathered in. but the next sticker should be diferent
Old 01-29-2004, 05:19 PM
MIGHTYMOUSE's Avatar
i just went through all of this.
for minimum safety to run 10.0 to 10.99 you need
5 point roll bar (door bar being on drivers side)
the rear bars and backseat bar must be welded to the main hoop
you need a 5 point harness
you need a multilayer jacket
this is in addition to a approved helmet, driveshaft loop, long wheel studs
may have left more little things out.
Old 01-29-2004, 06:02 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I don't think that RT66 will require T-top cars to have 10 pt cages... So where would you run into this problem? The rest of the tracks around here are IHRA.
Old 01-29-2004, 08:38 PM
Motorboater
Well of course my main concern would be the IHRA stuff but I want to be NHRA legal,too, no reason not to be.
Hell I don't know what the IHRA rules are, I know they are more leniant, but still don't know what they are.
Old 01-29-2004, 10:28 PM
Mike 01WS6's Avatar
IHRA is better IMO...LOL. You get away w/ more stuff in that sanctioning body.
Old 02-07-2004, 05:01 PM
Default points
heres a paragraph i made for the fast ls1 site because as u stated[ita also post in ls1 tech a few times as people asked ] alot of people are useing the wrong terminoligy] ,a cage is a cage and a roll bar is a roll bar[a roll bar can have 5pts 6pts 7pts and8 pts,a cage can have 6 pt ,8,10 12pts] a lot of people call up for cages and their trying to ask for roll bars its a common mistake
,most cages are actualy are 6pt unless 2 diagnal bars go to tunnel or frame connectors[before everyone jumps on me the 2 side bars usually go to the front uprights so unless you have the 2 diags like i said and they are mandatory when a cage is put on plates[pge 209 of rule book see diag. read D] if its a chassis car[ ie chevelle,malibu,corvetteanything with a full frame under it]the cage then has to be mounted to the chassis and dosnt require the 2 diags to tunnel. what else is needed are ,a window net,padding anywhere drivers helmet can contact[pge 203], and the instaler should put tabs for required shoulder harness [so its bolted to spine bar and cannot slip off you in case of accident]and if you go faster than 9.99 a chassis cert that should cover the basics hope this helps. bob
@ nrc motorsports
