Converters and Motor Plate
Another post got me thinking. What is different about a converter built for use specifically with a motor plate?
Is it just that the bolt pads are thicker (by the thickness of the plate)?
That doesn't sound safe at all.
Converter really needs to be built to the application. Also you can not just go spacing it off the flexplate or the converter hub will not engage the crank hub which is what helps align the converter while bolting it up.
