MSD 2 step guys come in..
Quick question, where does the unit mount? From what i understand it is a plug and play unit that plugs into the wiring harness. Does it mount in the harness that is on the passenger strut tower? I am in the process of doing the wire tuck and i may reconsider if that is the case.
i just figured out which pin was clutch switch on the PCM and got my signal there... only problem is it left a bunch of wire in the engine bay that i have to clean up. It seems alot easier than going into the car tho
