Drag Racing Tech
Kooks 2" and manual rack
Old 02-13-2012, 08:47 AM
buzz12586's Avatar
Default Kooks 2" and manual rack
I thought I had read at one point there was an issue with running 2" Kooks headers and a manual rack. I can't seem to find the thread again, but is this still the case?
Old 02-13-2012, 09:38 AM
TurboStangJON's Avatar
I know people often have issues with a 2" header hitting the steering shaft when switching to a manual rack. However, I have only seen this on LS engines and I don't know if you would have problems on an LT. It's very hard for vendors to make a shaft that fits every header/engine combo so the universal one often doesn't work. If you plan on keeping the factory column the fix is to have a steering shaft custom made to go around the headers. I have seen a couple of people extend the column slightly just enough to get around the header. Also, another route I have seen is to go from the column to a joint/support that's welded on the framerail then down to the rack. Another option is to have the header modified in order to fit your steering shaft.
Old 02-13-2012, 09:42 AM
buzz12586's Avatar
I should have stated that there will be an LS motor in the car.
Old 02-13-2012, 03:56 PM
LS1Tech Premium Sponsor
ssvert99's Avatar
we have bolt-in mounts for an offset manual rack conversion which should fix the clearance issue, and we can set you up with a custom steering shaft if need be as well.
Old 02-13-2012, 05:13 PM
Race your car!
JL ws-6's Avatar
You have 2 choices. Offset the rack, or remake the #1 primary, unless Kooks fixed the problem.
The #1 primary, is SO far in the say I have serious doubts if it will even clear a stock rack and steering shaft, nevermind an aftermarket rack.
Old 02-13-2012, 07:32 PM
10 Second Truck Club
67SS509's Avatar
My Kooks are 1-7/8 and the #1 tube hit the steering shaft going down to my manual rack. I extended the steering column 3-4" to get around it. Still close though.
Old 02-13-2012, 07:47 PM
Race your car!
JL ws-6's Avatar
The 2 inch it's almost impossible to extend the steering shaft that much, the U joints in the steering shaft will be at the point of binding up. Only way you can get away without modifying the header is if you offset the rack, and if I had a choice between modifying the header and shifting the rack over, I'd modify the header in a minute.
The #1 primary needs to snake down towards the block more... plain and simple. Josh @ KY speed did a BIG set of headers for smkn95 on here, they were either 2 1/8 or 2 1/4 and he routed them so the headers had plenty of room around the steering shaft (wrapped them tighter to the block).
I don't know why this hasn't been fixed yet, the 1 7/8 stepped to 2 inch headers I had from kooks barely cleared the stock steering shaft, with an aftermarket rack and k member there was no way.
I don't think there's a whole bunch of people that are using any stock suspension parts, and actually need a 2 inch header, that being said, why the header wasn't built and test fit on a car with an aftermarket rack and k member I can't even start to guess.
Old 02-13-2012, 08:26 PM
SMITH's Avatar
It will work just fine if you just extend the shaft down some. Here is the best picture I could find of my nitrous car showing the steering shaft. I had a BMR K-member at first and now a RaceCraft and it worked fine with both of those and the 2" Kooks.
Old 02-13-2012, 09:48 PM
minytrker's Avatar
I extended my steering shaft and used new u joints. Been like that for 3-4 years now. It actually turns easier with my new setup than the old stock one.
Old 02-14-2012, 07:21 AM
buzz12586's Avatar
Thanks for the info guys.
Old 02-14-2012, 10:01 AM
Race your car!
JL ws-6's Avatar
You guys used a different U joint then the ones I have, that's how you got away with that. Makes sense now, the flaming river ones I had to work with wouldn't allow for that much angle without feeling like it was going into a mechanical bind.
Header primary on #1 still should be moved in on those headers though, it's not like the extra bend is going to kill them.
Old 02-14-2012, 01:54 PM
If one manufacturer would move the #1 tube in everyone would end up buying that particular header. Someone like Kooks or American Racing would make a killing.
Old 02-14-2012, 04:29 PM
Race your car!
JL ws-6's Avatar
You would think that would be all it would take to make it happen.
Every guy buying a set for a race car that's going to have a manual rack, would buy that brand/model header, no question.
But yet it hasn't happened. If someone were to offer a service, ship me your drivers side header and I will cut out the portion of the #1 primary that doesn't clear and make it swing inwards and back out, for a reasonable fee, that guy would probably make even more money. Makes me want to buy a tig welder and go buy a bunch of 1 3/4, 1 7/8 and 2 inch 90 and 45 degree prebent tubing, and a good band saw.
Old 02-14-2012, 06:40 PM
studderin's Avatar
I think the 2' ARH clear? I remember reading a thread about somone switching to them from kooks.
Old 02-14-2012, 06:44 PM
Race your car!
JL ws-6's Avatar
I don't know. I do know what needs to be done to fix the problem, but I stopped worrying about it the day I decided to put a big block in the car... I already know the headers I need have to be built.
Old 02-14-2012, 07:29 PM
minytrker's Avatar
Kooks should read this post. They argued with me years ago saying there headers fit perfect it was my cars,lol. Guess lots of people must have messed up cars lol.
Old 02-15-2012, 01:23 PM
Race your car!
JL ws-6's Avatar
Every car with something other then a stock rack in it, is probably considered messed up.
Old 02-16-2012, 01:25 PM
Josh@KY-Turbo's Avatar
The #1 primary needs to snake down towards the block more... plain and simple. Josh @ KY-Turbo did a BIG set of headers for smkn95 on here, they were either 2 1/8 or 2 1/4 and he routed them so the headers had plenty of room around the steering shaft (wrapped them tighter to the block).
Fixed the Josh@KY Speed to Josh@KY-Turbo for you.
They were 2 1/4" primaries. Spark plug access is as good or better than manifolds. Ground clearance is as good or better than the 2" Kooks he had. Steering shaft clearance in his case is as good or better than the headers he had.
Old 02-17-2012, 09:07 AM
Race your car!
JL ws-6's Avatar
Josh sorry about that, at least I got your name right! I'm terrible with that stuff.
The headers you built (way the #1 was routed compared to the standard copy of the grotyohan design that pretty much every other header was based off of) were done in a way that will create more clearance hands down.
Why noone else ever did them that way, well I gave up trying to figure it out.
Quick Reply: Kooks 2" and manual rack
