suspention, launch help...
Ok ive searched but no definite answers other than sponsors pushing their stuff or keyboard experts, so ill try here.....
Bottom line cant launch for ****, just blows the tires....
275/50/15 MT et street drag raidials tried 20-14 psi no change
BMR lca with relocation brackets, (ive tried both holes for settings)
Adjustable PHB
BMR springs front and rear
Bilstein HD shocks front and rear
front sway bar off, stock rear bar.
odd part is my last fbody, i had the same spring shock compbo and i could launch. so idk
ideas?? besided buy XXX for $10000 lol
Adjustable PHB
Yea, I have qa1's all around. The 275#'ers are the qa1 brand. They're actually getting to the point where they need to be rebuilt since they're leaking. After this season I may pick up some double adjustable if I can get the extra $$$
If you're full weight, go with the 300# or 315#. My car sits really low in the front due to the light springs and full nose weight.
I didn't even think about that. I run the same tire, but I'm completely stock engined. But even a stock LS1 shouldn't have problem with traction once the weight transfers. The HD shocks are more of a road shock than straight line. While fine in the rear, I don't think it's allowing the nose to rise and shift the weight rearward. But that's my opinion.
First the tires are not too short, I'd try putting more air in the tires. I ran 275/50/15 M/T drag radials on my Camaro with stock suspension. 22-24psi was best, I dropped to 20psi and it spun a little bit, then dropped it down to 18psi it spun even harder. Put the psi back up to 22psi and it hooked, I've found that radials do not like low tire psi like slicks do. My car was bolt-ons and 150 shot, auto w/ 3600 stall, 275/50/15 M/T drag radials, completely stock suspension. It dead hooked and ran 11.40's with 1.59 60'.
I had a problem last year with tire spin, I removed the LCA relo brackets and it helped a ton. Over this past winter did some careful weight removal to change bias and now the car dead hooks on same tire you're running. Stock original springs and shocks, LCA's, short TA, and a dray/sway bar for suspension work.
https://ls1tech.com/forums/drag-raci...gs-shocks.html
LS1Tech Premium Sponsor
None...
The good shocks will use a lighter weight spring with whatever rate works for your combo. The rear springs are borderline for what you're doing, but you can go with a rear coil-over setup if you desire adjustable ride height and custom rate springs as well. You can easily sell off your existing spring set and recoup that money toward the right parts for your needs, then the out of pocket expense won't really be that bad.
