MWC Manual Rack with UMI K Member
Was wondering if anyone out there has both of these components together,
I was looking to buy one and I was told by MWC that they couldn't guarantee that it would fit, So if anyone can help out with some answers to this would be great. Car is an 00 WS6 if that matters. Thx
LS1Tech Premium Sponsor
We personally haven't tried to install our kit on the UMI k-member is the reasoning behind this. Our manual rack conversion setup is designed to be installed on a k-member with the oem power rack mounts in the oem positions. If that k-member had a oem power rack on it already it *should* work.
The K member has the stock rack on it now, so with that it might possibly work? I would love to try out the product out, if I were to order this, and it didn't work, might I be able to return the product?
Returns are no problems with an authorization, but if you are doing a simple oem power rack to our full manual kit conversion then there should be no issues requiring returns.
If the stock rack will fit then our conversion package should be no problem. The adapter bracket is setup at the same dimensions as the oem rack at the mounting points, including the sleeve that the bolt goes through so no trimming should be required.
There is a thread on here somewhere with a pic. But you can swap the idler on the alternator mount for a ribbed one and run a short belt.
