Weight Reduction because RACECAR
Just though I would throw this up...all items weighed on a digital scale accurate to .2lbs. TOTAL = 451.6 to date Car now weighs 3066#. I know where 40# more is...so 3026#.
Add back in the 67# for 8pt cage and ~20# for Kirkey seat and mounts brings her back to 3113#....Not to shabby for a heavy *** T/A with an iron 6.0 and S60
Badass!! What all did you remove ?
Now call Midwest Chassis and order the complete chrome moly setup with their spindles and lite weight Strange brakes and you should be in the 2800's. Lite weight rear brakes also. And get some lite rims too. And cut out every bracket that is no longer used. Manual brake master and manual rack. Get rid of all the wiring. Take out door crash bars. Glass hatch and hood, lexan windshield and hatch will even be more lite. Then if you really want to get seriously lite. Cut the front end up. But you will need a full cage with bars going to the front to weld the front shock towers to. Check out the sticky about weight reduction. Lots of good info.
Lol. Good point. I hear ya on the wallet mods. You did a great job So far.
Have you thought about removing the rear bumper support? I also see you removed the upper pan hard bar.. How does the car ride with it off? I heard that it's unsafe to remove the upper pan hard bar..
How's the hood at speed after removing under hood bracing?
Friend of mine took all the bracing out from the hood and it flops around quite a bit at highway speeds and above.
Please share some pics of the underneath and how you went about it?
