What is the best way to launch a m6?
i pull the clutch up till it just grabs,raise the rpm's(2,500 on my car)then dump and floor.is this right or am i all wrong??? thanks for the help.
<small>[ October 14, 2002, 01:46 PM: Message edited by: Pro Stock John ]</small>
"The Drag Racing Director"
Re: What is the best way to launch a m6?
That sounds pretty good to me. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Need more info on your set up so we can evaluate your technique. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
I'm with coach we need more info. otherwise what your doing sounds ok <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
ok my set up. 2001 ws6 ta.r.g.r st2 heads,mti hammer cam,mac headers w/off roads,b&b try flo exh,lid,mass air,asp pullies,free mods,12bolt w/4.10's,pro 5.0 shifter,fraim cont,lower cont arms,pah rod,nitto tires,ls1 edit,...times 11.71(new best) at 117.8 mph and 1.89 60 foots. car makes 424 rw hp and 407 ft tq. how should i lonch this car,i need to go faster. thanks.
your tires are whats holding you back. Get a set of ET Street or ET Drag, rev it up to about 4500 or more depending on how good the track hooks, at the last yellow floor it and lift up on the clutch as fast as you possibly can. if it deadhooks you might yank a wheel or two, very cool <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
ok....so your saying on the yellow light floor the gas,then on green dump and go right.
SIDE NOTE,the b&b and macs are not as loud as i thought it would be. infact,my mustang w/flomasters off roads and 1.58 headers is louder.
thanks mike c.,
thanks mike c.,
Dont wait till green to go , that will put you in the 1 second reaction time range. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Here's something else, which clutch are you running, maybe I missed it. Do you have a line-lock? Heating the clutch up too much trying to do burn outs or "til it grabs" kills 60's.
Line lock, ET streets, 26x11.5 since you have the 12 bolt.
I have a heavy (3750 lbs.)M6 vert, with just about the same mods. If you have a good after market clutch, hold it @4500-5500 rpm depending on the track, clutch on the floor, don't heat it. On the last yellow lift off the clutch, again how fast and how hard depends on the track that day and how big your "fella's" are, nail the gas and your gone. Listen for the bog or spin and adjust for conditions. If you wait to the see green, your late. It works for me.
I too missed your clutch type.
My setup is very similar to yours. I launch off of a 6600 rpm rev-limiter with a clutch dump. This nets me 1.59-1.60 pretty consistently. If I launch at lower RPM, my car bogs badly. If my rev-limiter was higher I would launch at an even higher rpm.
Good Luck
Mark
<img border="0" alt="[Camaro]" title="" src="graemlins/camaro.gif" />
Good Luck
Mark
right now i have the centerforce w/master cyl,and it kind of sucks. i want to get a new one for next season any suggestions??? with the centerforce if i dont get the rpm's up to 1,500 the car shimmies off the line. THANKS GUYS.
