Drag Racing Tech
long or short torque arm and why? any problems with madman's torque arm??
Old 03-04-2005, 12:10 AM
chpmnsws6's Avatar
Default long or short torque arm and why? any problems with madman's torque arm??
why would someone put a short torque arm on there car?
why would they put a longer one on there car?
lift the front end to much? plant tires to hard? not lift the front end up enough? it makes some sense, but yet it still doesn't.
the locals said a few people have had problems with Madmans torque arm (the one i've been looking at) but i can't find anyone complain about em except the 10 bolt guys (since he won't make it for em) but i've got a 9 inch so thats not a problem
car is a track car with maybe 100 miles on it a month in the summer
thanks for any insight
Old 03-04-2005, 12:11 AM
chpmnsws6's Avatar
sorry, a bunch of questions in a single thread but i didn't wanna be like BlackBeast was
Old 03-04-2005, 08:54 AM
"The Drag Racing Director"
Coach 02 A3 Z/28's Avatar
I run the Madman Tq arm with no problem what so ever. I cut low 1.3 60 foots with a H/C LS1 346.
I would like to hear about your friends problems with the Madman Tq arm.
Coach
Old 03-04-2005, 10:51 AM
LS1_PNYTAMR's Avatar
hmm.. i wonder i will want to get a tq arm sooner or later for my cam and nitrous, wonder if shooting for a 1.59 60 requires one, other then a reinforced stocker. also will I be making enuff power to even need one? and what would ya'll reccomend for a cam/150 shot car, and yea i leave on the gas most of the time.
Old 03-04-2005, 11:05 AM
11 & 7 Second Clubs
Race Car Driver's Avatar
Are you saying that the word "Madman" in and of itself does not generate enough confidence such that you are willing to buy his torque arm without checking it out. (Is that a compound sentence?).
Old 03-04-2005, 11:39 AM
chpmnsws6's Avatar
i'm mainly trying to understand why people go with a longer when then put suspension limiters on there car
Old 03-04-2005, 11:55 AM
12secSS's Avatar
A shorter TQ arm provides 'stronger' leverage to plant the rear axle. Using a longer TQ arm will not allow the twisting of the axle to transfer that leverage to the rear suspension and assist in providing better traction. Think of it in term of holding out a 2x4 that is 5' long with a 20lbs weight at the end and lifting it ... now would you be better able to lift that 20lbs weight if the 2x4 was 3' long (2' shorter)? I think you would.
Old 03-04-2005, 12:16 PM
chpmnsws6's Avatar
is there such thing as to long of a torque arm if custom made?
Old 03-04-2005, 12:28 PM
DopeFedZ's Avatar
Yeah there is a problem with Madman's torque arm! It put my car on the bumper and cracked my block when it came back down
But I wouldn't have any other TQ arm on it
Old 03-04-2005, 12:49 PM
chpmnsws6's Avatar
but doesn't putting it on the bumper slow you down? thought a car was quickest when it pulls em about a foot and then just GOES
Old 03-04-2005, 01:21 PM
DopeFedZ's Avatar
Your right but we didn't know what to expect from my car and we found out the hard way. Nothing a couple of adjusments wont fix.
Old 03-04-2005, 01:30 PM
12secSS's Avatar
YES! More than OE would loose traction.
Old 03-04-2005, 02:19 PM
chpmnsws6's Avatar
stiffen the front and rear shocks? put stiffer springs in the rear?
Old 03-04-2005, 02:25 PM
Slow Z28's Avatar
i don't know if that's generally true....
wouldn't the same principle be put towards loosening a bolt? why would the breaker bar that is a foot longer than the ratchet provide more leverage?
Chris
Old 03-04-2005, 03:27 PM
Stryker's Avatar
your lookin at it the wrong way slow z28.. its actually opposite. the example with the 2x4, the fulcrum (pivot point) is at the edge of your hand. while with the breaker bar the fulcrum is at the point closest to the nut. so if u can picture the pressure of the brick trying to force your hand down from 5 feet away vs 3 feet youd realize its relatively the same as the force applied to the end of the breaker bar on a nut.. technidick session over.
Old 03-04-2005, 03:34 PM
12secSS's Avatar
Look at it from the point of view of the bolt. It can resist the breaker bar if it is shorter. A longer breaker bar will not allow the bolt to resist the leverage. Same deal on a TQ arm suspension, the body having a long TQ will not allow the Axle to twist the suspension in to the ground as easily. Also think of it in terms of trying to lift weights with your arm extended, that is much harder to do than if your arm was closer to your body. That is how the TQ arm functions.
Old 03-04-2005, 04:50 PM
Race your car!
JL ws-6's Avatar
I've talked to a few people about this. I'm sure that there's an expert that can chime in here about it too. The shorter torque arm will "hit" the tires alot harder, and help out the 60 foot alot with a car that's not making a ton of power.. let's say under 500 hp to the tires for the sake of saying. Once you get into the real big power catagory ( 700, 800 or even more to the tires ) you aren't gonna want that short tq arm. The car now has ebough power to "hit" the tires the same with a longer torque arm. If you are still running a short arm with that kind of power... plan on doing a bunch of repairwork..as stated above. The longer torque arm will transfer weight slower, and generally keep the fron tires closer to the track. Slowing down the weight transfer would seem like a bad thing... but with say 1000 RWHP, you don't need it to slam the weight that quick, that kind of power does it on it's own. TQ arm lenth, and what works, really depends alot on the power level that you are at. If you are at the 300 to 500 power level, a short arm is probably a good thing. It will transfer weight in an optimal way for the power level. If you are at the 700+ power level, you'll probably want a longer tq arm. Arm angle also has alot to do with it too.. having the arm straiter also changes the way it "hits" the tires... more angle on the arm, harder it hits the tires, creating more nose lift. If you are at a level say around 600rwhp, a short arm could still be a good option, but you will want to run it at less of a pitch, more level to the ground so there is less lift created.
Don't take my word for this stuff, there's alot of experts that have built 100's of race cars on here that could answer this alot better than I probably have.
Old 03-04-2005, 06:20 PM
sikws6's Avatar
The fastest stock suspension car (radial or slick) is Rick Head of Innovative turbo 7.66@ 180+ mph has a BMR extreme torque arm on it and it's a "short" style torque arm,has a best of 1.30 flat 60' on drag radials I believe.The car just barely lifts the front tires and it's gone so yes you can have a very very high horsepower car and still use a short torque arm.....my.02
Old 03-04-2005, 06:34 PM
Slow Z28's Avatar
now i got it a bit better
Old 03-04-2005, 07:30 PM
chpmnsws6's Avatar
so the only problem with MADMANs is ppl hitting the rear bumper? from the way they were talking, it sounded like they were breaking them or not being able to hook with em or something
Quick Reply: long or short torque arm and why? any problems with madman's torque arm??
