Drag Racing Tech
Burnout - one side????
Old 07-11-2005, 09:11 AM
mako22's Avatar
Default Burnout - one side????
Went to the track this weekend - with my new line-lock I was getting some good burnouts, lotsa smoke. However, after I looked at my rear wheel-wells, I only had rubber sprayed on the drivers' side - almost none on the passenger side!
is this normal?
Old 07-11-2005, 09:38 AM
WhtLT1's Avatar
Its just signs of a weaker posi. Try to do a regular brake torque without the line lock and see if u leave 2 marks. Cause if its really weak (which i think so since it only spun one kinda hard with the linelock on) it will only spin the one doing a regular brake torque
Old 07-11-2005, 09:55 AM
mako22's Avatar
1) does that mean my rear is going?
2) is this hurting my launches??????????
Old 07-11-2005, 10:59 AM
SeeYaSucker's Avatar
Yeap, sure sounds like the Posi unit to me.
Old 07-11-2005, 06:16 PM
DaveX's Avatar
Sounds like a torsen posi to me. Sometimes mine does the same thing. Take it to a parking lot, come to a stop, turn the wheels all the way to make a tight turn and then give it enough gas to spin (but don't go crazy doing donuts ). Do it a few times and see if sometimes only one wheel spins. I've also noticed it in a straight line, usually when it's wet or I have very little traction for whatever reason. It seems to me it takes a certain amount of resistence to keep it locked in.
If it's a torsen, it's all mechanical and has no clutches. The factory unit in these cars isn't very strong, but if only one wheel spins sometimes it doesn't necesarily mean it's about to go.
Old 07-11-2005, 10:22 PM
mako22's Avatar
thanks guys for the ideas - just reviewed the tape, looks like there is some smoke coming from the passenger side after all - take a look (bonus: Vette kill )
http://video.ls1tech.com/Player.aspx?fileid=E947EEA4-43E4-4323-AAB3-03E79CC5870D
Old 07-12-2005, 01:40 PM
TWS
TWS's Avatar
Do you have a Zexel Torsen? If so, that would explain it. They are designed more for road racing, not for doing a stationary burnout at the track. I bought one brand new when I removed the original Borg Warner that was in my '94. The Torsen immediately started doing one-legger burnouts before at least half of my passes. I realized I had installed the wrong type of rear carrier for drag racing and got a line on an Eaton. While I was searching for the Eaton/waiting for it to arrive, I had to have a buddy go up with me each pass and act as a "spotter" to tell me if both tires were spinning or not. Big hassle.
Old 07-12-2005, 09:31 PM
mako22's Avatar
hmm - after reviewing the tape I may have overreacted - looks like there is some smoke coming from the pass. side after all :
Click here to see Video
