Drag Racing Tech
Wolfe minitubs are available for Fbods.........
Old 07-13-2005, 03:45 PM
Z06PSI's Avatar
Default Wolfe minitubs are available for Fbods.........
http://www.wolferacecraft.com/Search...CategoryID=180
Old 07-13-2005, 03:52 PM
Sandmann120's Avatar
Sweet. That's not a bad price, either.
Old 07-13-2005, 04:06 PM
Z06PSI's Avatar
Not at all.... just trying to choose a spring rate ... anybody got a suggestion.... full race with a 2900lb raceweight...
Old 07-13-2005, 04:11 PM
DMH Fabrication's Avatar
so can you still run a lca with them or do you have to switch over to 4 link or offset trailing arm to actually use the width you gain?
Old 07-13-2005, 04:15 PM
Z06PSI's Avatar
From what I understand is an offset LCA. Billingsley makes them.... anybody have any pics of an offset LCA....???
Old 07-13-2005, 05:28 PM
I'm pretty sure I just saw some on Wolfe's website?
Old 07-13-2005, 06:03 PM
Z06PSI's Avatar
see them .. thanks....
Old 07-13-2005, 06:24 PM
gator's 99TA's Avatar
the labor is the cutting and keeping the control arm and spring location stock. not the fabricated tubs. still a nice piece.
Old 07-13-2005, 08:03 PM
how is cutting that much labor? Seems like it would be easy to knock that out.
Old 07-13-2005, 08:13 PM
Z06PSI's Avatar
Sawzall and a cut off wheel. the only tools you'll ever need....
Old 07-13-2005, 08:22 PM
that and a plasma cutter always helps
Old 07-13-2005, 09:23 PM
Shon Herron's Avatar
offsetting the LCAs is the EASY PART!!
Old 07-13-2005, 11:32 PM
i guess most of us dont have a plasma cutter in thier garage? maybe you do
Old 07-14-2005, 05:32 AM
sawzall works great too. i would think cutting it out would really not be that bad. I have done 2 or 3 of them in the past. Guess it just depends on your skill level or somthing.
Old 07-14-2005, 06:17 AM
BTL FED's Avatar
There is ALOT of cutting, I used a plasma cutter and it still took a couple hours per side to get it how I wanted. I cut out 23 lbs of steel per side There is also the plate that goes across the frame, it is spot welded every 2-3 inches That is a PITA to get off.
Here is what mine looked like all cut up
Old 07-14-2005, 06:19 AM
BTL FED's Avatar
From what madman told me you need 150 springs in the rear, I run a 10"x150 on mine with 29.5x10.5x15
Old 07-14-2005, 07:07 AM
FASTFATBOY's Avatar
You cant run a stock rear spring with that setup, I would like to see what the drivers side tub looks like, that side is totally different from the passenger side. Well I am done with my mini-tub, you would know someone would sell a kit after mine is done.
David
Old 07-14-2005, 11:24 PM
Here's a stupid question, but will these still fit under the stock interior plastic?
Old 07-14-2005, 11:55 PM
Z06PSI's Avatar
Dont think so.. too tall....
Old 07-15-2005, 07:09 AM
in order to use the extra space gained, would you need to cut the front and rear of the wheel opening to get enough clerance. I've seen alot of people cutting the bumper and front of the fender opening...for a taller tire i guess??
