Drag Racing Tech
work to fit welds
Old 03-09-2006, 02:27 PM
hourang's Avatar
Default work to fit welds
besides grinding calipers, what other work has to be done to fit a 15x10 7.5bs weld prostar with 26x10 mt et drags? its the same height as stock, will it fit with minimal or no hammering or and im bringing out a sledge? just curious.
Old 03-09-2006, 02:30 PM
LS1TECH Sponsor
Steve Burger's Avatar
Be one with the grinder and you will be OK.
Old 03-09-2006, 06:01 PM
GM Muscle's Avatar
You shouldn't have to hammer anything. If your car is stock heigth you may have to shave down the bump stop.
Old 03-10-2006, 08:18 AM
hourang's Avatar
so is it pretty much the same size as the stock 275 tire?. whats the 10in tire compare to in mm? if anything the rear went up an inch or so from the 9" install.
Old 03-10-2006, 09:29 AM
HaulinHawk's Avatar
Grind calipers and cut off bumpstops.
Old 03-10-2006, 01:17 PM
GM Muscle's Avatar
Pretty much, the sidewall bulge is what usually hits the bump stop. I don't have any cross section and tread width numbers in front of me though. Basicly after you grind your calipers, load the rear, then check and see if the tire hits the bumpstop. If it does, just take your grinder to the bump stop.
Old 03-10-2006, 03:12 PM
hourang's Avatar
cool thanks guys!
Old 03-10-2006, 03:28 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I just bent the bump stop down to fit 26's, but cutting them off would be easy.
Old 03-11-2006, 07:52 AM
AFTICA's Avatar
After I put the 15x10s on with 275/50/15 M/T DR's I put jackstands under the frame and let the rearend drop until the bulge of the M/T touched the bumpstop. It looked to me that I'd have to do some dukes of hazard type jumps in order for them to touch. It was almost at full extension of the suspension before they touched so I didn't bother with the bumpstops. Should I re-think that decision?
Old 03-11-2006, 08:33 AM
SgtB's Avatar
nope you'll be fine
Old 03-13-2006, 05:44 PM
BAKED's Avatar
I grinded the calipers on mine today to try to get my weld's on and I have 28x10.5 on mine, it looks to me like I will have to run a small wheel spacer for it to clear. What did everyone elser do to fit their 28's????
