best way to launch
best way to launch
how do u launch an m6 car at track? ive got street tires and stock rear w/ a built t-56. what r pm should i go from. also how do u keep the car from rollin at the staging lights. how do u keep up rpms w/o allowing the car to move and red light???
Put a switch at the bottom of the clutch stroke that triggers a line lock. Light the last light, touch the brake and put the clutch in. Go for the gas pedal. Let the clutch fly or slip it and away you go. Hook up a two step to the same switch and you can foot it to the floor. No looking for the tach. Adjust for the best RPM.
I launch between 2500-3500 depending on the track conditions. The trick is to slip the clutch enough to keep the rpm's up, if you bog on the line you lose, thats it. It took me about a dozen or passes to get comfortable doing this on a semi consistent basis. and the best 60' time I have is 2.1 on 245 street tires (fuzionz). I think that 1.8 is possible with drag radials, those are my next mod.
Josh
Josh
thanx for the info guys, i hope to test it at the track as soon asi get my car from the shop. im getting 4.10 gears put in. what should i expect to run w/ the 4.10 plus my mods in the sig.
Originally Posted by ss1129
What exactly does side stepping the clutch mean?
it means you slip your foot off the side, and the clutch just pops off.
anyway, the best luck ive had with street tires is by not launching it hard.. it sounds counterproductive, but being smooth and easing out is alot faster then spinning.... thats how i get 1.8s and the occasional high 1.7 on street tires..
dont pop the clutch, the shock just breaks the tires loose and spins them. dont just mash the gas down.... smoothly but swiftly let the clutch out, and roll the throttle on...
if you want the killer launch, then get the tires and suspension, and prep the car for whats going to break (rear, then clutch and Ujoints)... but its fun when you can REALLY launch the car.
so will a stock rear end hold MT drag radials or should i just go with nittos, i can't afford to replace my rear right now so i need to try to play it safe as possible. i know that does not make much sense when i am at the track draging but oh well it is fun!!
Thanks for your help...
Originally Posted by DD966
What RPM are you launching at? Do you have to worry about 'boggin' at lower RPM launch?
with street tires? it changes from car to car.. the more worn out the front struts are, the better it'll hook.. i just kind of feel it around, really its around 2000.. remember im not trying to LAUNCH, but rather slip the car forward without spinning the tires loose.
with the slicks.. its a 4800+ clutch drop. probly higher now that i have a cam. i havent been to the strip in awhile ( convertible + no cage = booted)
