26 x 10 x 15 ET Drags, Scres, Tubes???
26 x 10 x 15 ET Drags, Screws, Tubes???
Im planning on ordering some of these for this season?
Do you guys think i can drive 15 miles to the track and 15 miles home on a slick?
Do i need tubes?
Do i need Screws?
Tony.
Do i need tubes?
Do i need Screws?
Tony.
Do i need tubes?
Do i need Screws?
Tony.
Do i need tubes?
Do i need Screws?
Tony.
Do i need tubes?
Do i need Screws?
Tony.
Do i need tubes?
Do i need Screws?
Tony.
The tubes weigh about 6 pounds and that calculates to about 90 pounds of unsprung weight on your rear tires - you don't need that.
Scews are not necessary for the hp you are putting out. Just be careful when you have the slicks mounted that they "don't" use tire mounting compound, it is slippery ****, that will cause the tire to slip on the rim. Have them use soap and water and wipe it off the tire and rim before seating the tire to the rim. Best is find a place with new tire mounting equipment where they don't have to use anything.
Hope this helps you out.
Race your car!
ET streets SUCK in the rain that I am 100% of. The drags will suck just as bad, and wear out qucker on the street... I'd change them at the track if I were you, but you don't have to... just gonna go thru them alot quicker if you dont. look at it like this, a pass at the track is 1/2 mile, 1/4 in each direction... that's 60 passes for a round trip to teh track and back... alot of uneeded wear.
