Drag Racing Tech
Spray in bedliner instead of carpet
Old 04-13-2006, 10:56 AM
SVT THIS's Avatar
Default Spray in bedliner instead of carpet
Remember the old Roadrunners interior? Ha, I saw remember but I was born 15 years after they were made...
Anyways, they lacked carpet and had a bedliner-ish floor didn't they?
Could weight be saved by using a spray in bedliner instead of lightweight carpeting, or is the lightweight carpeting the way to go?
Old 04-13-2006, 12:41 PM
DopeFedZ's Avatar
https://ls1tech.com/forums/drag-racing-tech/428514-beadliner-spray-heavy.html
DopeFedZ's Avatar
Not too much info but that is all we could muster up.
Old 04-13-2006, 01:32 PM
spootnik's Avatar
I don't know about putting it in a car. but I'm using rhino-liner instead of carpet in my 4x4
Old 04-13-2006, 01:50 PM
ss1129's Avatar
I dunno, the only thing I think of when I picture that is the redneck guy from the simpsons. I would just go with light weight carpet.
Old 04-13-2006, 03:07 PM
Racer8102's Avatar
THat stuff actually weighs quite a bit, I used to help a guy with his Line-X business, but will help with sound deadening alot. I have sprayed it in old 4x4's and jeeps, but never seen it done in a car.
Old 04-13-2006, 04:16 PM
93formto98T/A's Avatar
Pretty sure it's heavier than some lightweight carpet. My LWC weighed 12lbs and went from firewall to back of deck.
Old 04-13-2006, 04:53 PM
SVT THIS's Avatar
Hmm.. I'll have to check it out. If its cheaper than new carpet and lighter than the old carpet I'll have to go that route.
EDIT: 7 bucks at Autozone, looks like this is what I'm doing!
Old 04-13-2006, 06:04 PM
DopeFedZ's Avatar
I plan on using the spray in beadliner but only because I won't have to bullshit around with thin as carpet that ends up getting all crappy looking after getting in and out the car a few times. Spray it one time and I won't ever have to think about it ever again.
Old 04-13-2006, 07:47 PM
SVT THIS's Avatar
Well I just pulled out my carpet and bought the spray. Looks like I'll be spraying it up tomorrow!
BTW this bitch is loud without all that carpet and insulation!
Old 04-13-2006, 10:22 PM
Jeremiah's Avatar
I do bodywork for a living and remove/replace beds all the time. the ones with the spray in bed liner are a hell of alot heavier than without. I think your going to end up the same weight wise but have a crappy looking interior and more road/engine noise.
Old 04-13-2006, 10:37 PM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
http://www.rhinoit.com/faq.htm
Q. How much weight is added to my truck?
A. Your Rhino Lining will add between 45 and 65 lbs to the weight of your truck depending on the size of your truck bed.
Old 04-13-2006, 10:40 PM
SVT THIS's Avatar
This spray is totally diff. than normal truck bed lining. Sorry, I shoulda mentioned that. I think it would probably suck as a bed liner actually. Its not tough enough for all that wear and tear-however, it should be good for normal car use.
The 2 cans from Autozone cost me about 15 bucks and weigh about 3 pounds. I'll let you know how it looks-and I'll be honest if its complete **** as long as you show me where to buy some cheap carpet
Old 04-13-2006, 11:01 PM
Ru2slo_99's Avatar
If you do use a real spray in bedliner, you dont have to spray it thick. I know lots of places spray the bed area thin and around the edges thick so it looks thick and rugged.
Old 04-14-2006, 12:03 AM
phoenix's Avatar
well keep us updated and dont forget to post pics
Old 04-14-2006, 06:25 PM
What are you planning on doing about the wiring that runs along the floorboard and console? Can't spray over them....
Old 04-15-2006, 12:57 AM
SVT THIS's Avatar
^------ How much you wanna bet?
Old 04-15-2006, 10:55 PM
ninetres's Avatar
lol.
+1 for pics lol
Old 04-16-2006, 04:35 AM
Restricted User
CAT3's Avatar
jesus, why argue about how much the **** weighs? Get off your asses and go weigh one can of the lining spray, no f*cking way is it close to 45 lbs. Hell, it aint even 10lbs and I am sure you can spray the interior flooring (carpeted area) with one quart. Hell, I used an 8oz bottle of POR-15 and covered two coats on my new 9". Guess I will have to get off my *** tomorrow and see how much one quart of spray in bedliner weighs
Old 04-16-2006, 04:33 PM
SVT THIS's Avatar
Dude, I think you need to make sure there isn't a badger up your *** or something. You sound a little stressed out about a couple little posts.
I weighed the can, its like 16oz. I used 2.
Quick Reply: Spray in bedliner instead of carpet
