Drag Racing Tech
Bogart ?
Old 03-15-2007, 07:56 PM
HAMRHEAD's Avatar
Default Bogart ?
About to pull the trigger on some 15x10 Bogarts and wanted to get some opinions or complaints on them, if any. Which model would you recommend? I was looking at the Bolted RT but I like some of the others too. What is the difference between the Floyd bolted and the regular bolted?
I would post this in the wheel section but am looking more for a drag opinion. These wheels will not be on the street and am just concerned with the rears for now.
Thanks!
Old 03-15-2007, 08:49 PM
TwoFast4Lv's Avatar
My Bogarts on my LT1 fit perfect. No work needed
Now on the LS1 we had to shave the nubb's off the brake calipers to fit
Then again they were ordered for a LT1 car..
Old 03-15-2007, 09:12 PM
ls1pwrdss's Avatar
if you go with the d 10's 15 x 9.75 no shaving no nothing no spacers only have to buy the special lug nuts
Old 03-15-2007, 09:36 PM
LS1-STANG's Avatar
I have the Bolted RTs and LOVE them well worth the $$$$
Old 03-15-2007, 10:05 PM
Navy David SS's Avatar
Great wheel. Bolted RTs.. Nothing special about the lug nuts. Just get the right size. Buy the open ended ones for the rear. Mine are 15x10 w/6.5" B/S for a 1 1/4" narrow rear-end.
Here's a picture of mine with Hoosier 30x10.5x15R
David
Old 03-16-2007, 09:42 AM
LS1SpeedAddict's Avatar
Dont get bolted RTs. Get the welded, my father had a set of the bolted and they were a **** to clean and polish becasue of the damn bolts, plus I dont think the bolts look good. Go with welded all the way. Either way bolter or not bolted, Bogart is the way to go.
Old 03-16-2007, 11:47 AM
AlmostfastLT1's Avatar
I had a pair of the D10 bolted, the quality was awesome and Steve at SJM was such a great help!
Mark
Old 03-16-2007, 12:01 PM
Race your car!
JL ws-6's Avatar
I love my welded r/t's, they're a great wheel
Old 03-16-2007, 12:48 PM
02Z28's Avatar
Got mine from Steve at SJM and they fit great.
Old 03-16-2007, 01:31 PM
SERIALPIMP's Avatar
Those look sweet on all yalls cars,
Do you feel like they were worth the money?
Old 03-16-2007, 01:50 PM
02Z28's Avatar
They aren't cheap but I do feel like they were worth it. Better looking then most wheels and lighter too. Plus if sell them you can get most of your money back it seems like they hold there value pretty well.
Old 03-16-2007, 02:36 PM
Race your car!
JL ws-6's Avatar
They were definately worth it.
Only regret I have.. is that I have to drill them for screws for the rear tires... I'm gonna hate doing that.
Old 03-16-2007, 02:45 PM
ABA383's Avatar
Another vote for the Bogarts...They fit great, look great, and are nice and light...Click on my sig pix to see them (welded R/Ts) on my car...
--Alan
Old 03-16-2007, 03:00 PM
silverbeast's Avatar
I love mine. Bolted RT's. The only problem ive had is with the lug nuts. I have a 12 bolt with bigger studs and i am useing weld lug nuts that pass all the way through the wheel. I cant get them to tighten up without ******* the studs up. i have stripped one already.
Old 03-16-2007, 09:01 PM
SJM Manufacturing Inc's Avatar
Weld lug nuts that are used for Prostars/draglites are TOO long. Do NOT use them. You must either cut them shorter or I can assist you with what you'll need.
Even if they are cut shorter, for others reading, they will NOT still work with every style wheel as some of ours have a special milled cut that need smaller diameter washers!
E-mail or call me directly if anyone has questions or comments please. We build the wheels to fit the application. Even an LS1 F-body is different then an LT1 F-body build.
Old 03-16-2007, 09:02 PM
On another note, be careful when you're taking them off as you may have mushroomed the shanks on those lugs. This means you need to be careful when pulling them through the milled bolt hole.
Old 03-16-2007, 09:41 PM
hey steve, thanks for the reply. My studs are 3 in long and when i screw the lug nut on it goes on fine and has about 1/2 an inch of thread left. but when i put the wheel on and try to use the weld lug nuts as soon as it gets in the wheel good it gets VERY hard to turn. Its the craziest **** ive ever seen. the lug will fit fine through the hole in the wheel but not if im trying to put the wheel on. what kind of deat can you make me on a set that will work? thanks Charles
Old 03-16-2007, 09:49 PM
HAMRHEAD's Avatar
Did most you guys go with drag brakes or are you using stock brakes? You get a deeper lip with a wheel for the drag brakes but not sure how much of a difference it is.
Old 03-16-2007, 09:51 PM
SScam68's Avatar
what style of wheel are you running in the front?
Old 03-16-2007, 10:27 PM
HAMRHEAD's Avatar
Those look like M/T's in the front
Quick Reply: Bogart ?
