Drag Racing Tech
Those w/2 steps (rev limiters), N/A, 5000-6000 converter, what rpm do you launch at?
Old 11-18-2007, 07:00 PM
9 Second Club NA
Dragaholic's Avatar
Default Those w/2 steps (rev limiters), N/A, 5000-6000 converter, what rpm do you launch at?
My current setup will consist of 29.5x10.5 ET Drags, 4.56 (more than likely will have to step down), ProTorque 5800 converter, etc. I have the Lingenfelter rev limiter, also known as a 2 step, but technically a 1 step, and was wondering those with similar setups, what rpm works best for you on the launch?
My previous setup I launched right off the converter, which was somewhere in the lower to mid 5000, as I didn't have any type of launch rev limiter.
Old 11-18-2007, 09:59 PM
car_fixer's Avatar
the number i hear is within 1k of the flash rpm of the converter, mine flashes to 5300 i stage at 4500 (and occasionally have been know to put it on the bumper lol)
Old 11-19-2007, 03:34 AM
6 & 8 Second Club
mrdragster1970's Avatar
4200 with a 29 X 10.5W Hoosier on slow car
Old 11-19-2007, 07:26 AM
9 Second Club NA
Dragaholic's Avatar
So is there a rule of thumb or an equation for something like this? I'm so busy with work, that I may make it out to the track 4-5 times a month if I'm lucky. I just want to get my car dialed in as quickly as possible without having too many different adjustments. I wanted to get close, then go from there. I know that's hard to do with so many different combinations out there, but I figured someone had to have somehting similar. Thanks.
Old 11-20-2007, 06:39 AM
9 Second Club NA
Dragaholic's Avatar
Anyone else?
Old 11-20-2007, 07:55 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Start at 4500 and keep bumping it up, have to see where you end up.
Old 11-20-2007, 08:26 AM
9 Second Club NA
Dragaholic's Avatar
So I'd be wasting my time starting out at 1500 rpms and working my way up?
Old 11-20-2007, 09:10 AM
LS1Tech Co-Founder
I would think so.
Old 11-20-2007, 09:29 AM
PewterZ28's Avatar
My converter flashes at 5200. I set my two-step anywhere between 4000 and 4600.
Old 11-20-2007, 09:56 AM
Dave J's Avatar
my converter flashes at 5200 as well and I just lauch off the tranny brake at wot
the 2 step is for when I run in the 10.90 class and I have to slow it down a bit
Old 11-20-2007, 02:25 PM
chrismorales75's Avatar
My car ran fastest leaving at WOT on the TB running on the motor, on the n20 is left a little harder dropping the rpm to around 3500.
Old 11-24-2007, 07:10 AM
9 Second Club NA
Dragaholic's Avatar
Is this limiter going to help the car leave softer so that it wheelies less? I also want it for consistancy. Anyone else want to pitch in on what rpm they set their limiter to?
Old 11-24-2007, 11:25 AM
My experience on the motor using the rev limiter at a lower rpm it will wheelie less, leaving with less rpm on the N20 it made mine wheelie more.
