K&N air filter removal and added airflow?
Not something I wanna' do more than once, but, next time at the dragstrip (this week [weather permitting]), since my MAF is screened ... well, I'm doing a run with the K&N completely out of the car.
My intake setup is 90/90 with 85mm MAF and 85mm airlid and hood blockage at the bottom snorkels has been removed by cutting out 2 1/2" x 5 1/4" gaping slots from the fiberglass behind each of the bottom snorkels > WS9 ram air hood has the WS6 taller airbox and is sealed airtight around where the hood meets the airbox hole. I also put on the Fast Toys JAAM air plate.
Looking for someone who has done something similar to post any impovements in ET or MPH. Going from stock to K&N filter 5 years ago, the car responded a little better. With NO filter at all ... and all this other stuff done to the car ... has anyone seen improvements worth mentioning from doing a similar test?
well in my case since it did lean it out a fair bit there is forsure alot more airflow there so maybe if I fatten it up a bit and I will run without one all the time since mine is a track only car anyway
Retired Street Racer
Haha, a pound or two here or there adds up. You'd be surprised how light the car is and looks stock in the inside, minus the seat swap. I still have all of the plastics and door panels.
Thanks man. It is a lot of fun chasing the record and doing small things to tweak the car to where I want it. If I didn't strive for it, I would probably be bored and sell the car.
FWIW, i picked up 5 hp on the dyno by removing the lid and and filter. im speed density so there was no maf. just an open throttle body. next time at the track, im gonna throw a panty hose over the tb and run it like that. i suppose the same could work for a descreened maf.
The dyno will not show any gains. I have tried SEVERAL times on the dyno with no change whatsoever. However, at the drag strip I ALWAYS gain 1 tenth and 1 mph from removing the air filter. If you have a ram air kit of any kind, even free ram air, then removing the filter allows more air flow as you go faster and faster down the strip. I'm not just talking about one track visit, more like twenty or thirty trips with the same results every time. I simply make a couple passes with the filter in and then remove the filter and immediately I pick up 5 hundreths to a tenth and right around 1 mph.
If you have free ram air or a ram air kit, try it and see for yourself.
That's all I care about is track gains ... real-world stuff ... there's a lot of velocity at 100+ mph. No way you could see zero gains at the track ,or at higher speeds out on the streets, by removing the filter ... stands to resaon IMO. UNLESS, of course you have a restricive intake, near stock cam, AND a restrictive exhaust ... even then you should see something. I'll post up tomorrow night if I make it to the track.
The guys above are hauling serious *** and therefore undoubtedly seeing a difference.
Troopercar > My cars not too shabby either. You don't know what airflow I have going on my car ... it's absolutely nowhere near stock. Check out my F-Quik page in my sig while I download the pics I took of the airflow I'll be looking at when I run the car tomorrow night. It's not your standard ram air setup.
