Kirkey Pro Street Drag Seat
I would use two pieces of tubing with tabs welded on it to reuse the stock mounting bolts and then the seat sits on the tubing and you weld tabs to the side of the tubing to secure it by drilling through the side of the seat once it is in the position you want.
You can also bend the tubing to manipulate the hight, some people like the seat super low, while some people that are not tall will like it mounted up higher.
I have the steel mount welded on cage, and the use the Aluminum Mount, trim it and bolt it to the back of the seat, and bolt other side to the mount thats welded to the cage.
